Tow Hook Question
jpitman is correct, this is a knuckle, not Acme, thread. Very few folks are familiar with it, so it is not surprising it was mislabeled by someone, even a "specialist". I can cut Acme threads on my lathe- simple stuff. I do not have a knuckle thread insert nor have I ever seen one.
Ok Im wrong, just repeating what the bolt guy told me. Regardless, I DO NOT want a license plate up front and am getting an antique registration plate for my 82. Problem solved and very cheaply at that.
So I just had to find out how little I know and googled "knuckle thread insert", and now I have seen one, actually a bunch, at least in web images. I've fallen off horses before, including some high ones...
Acme is an easy mistake to make, as there are not many threads at 8 TPI in the relevant diameter range. I have found about the only thread mix that can work for short lengths is M5 (p=0.8mm) will fit US thread 10-32, as 0.8mm pitch = 31.75 TPI. In soft materials (eg composite , probably alloy) up to say 1/2 long the force required to screw in is not high.
jp 83 Euro S AT 55k
jp 83 Euro S AT 55k
Could have obtained an extra stock hook and cut off what wasn't needed and then built off of that piece.
