928 Forum 1978-1995
Sponsored by: 928 Specialists
A 86.5 Intake Refresh Picture Thread from a first-timer
Old 08-29-2013, 05:56 PM
syoo8
syoo8's Avatar
Mike and Jeff, I will follow your advice.
I got a set of intake covers from 928 Specialists. They fit perfectly over the intake ports, and now nothing will get in there. I highly recommend that if you are doing this for the first time, you have these covers ready as you are pulling the intake runners off. Before fitting the covers I decided to triple check and I vacuumed the intake ports one more time. When I checked to see if there was anything in my shop vac I found two small rubber chunks of spark plug wire insulation. I don't know if the shop vac picked them up in the intake ports or maybe afterwards. Makes me very nervous…
The "bonded rubber buffers" on which the air guide throttle body sit: one of them is good:
And one of them is not good:
I have no clue how I'm going to take it out. There is no cross section so I can't get a vise-grip, wrench, anything on it. I am worried about drilling because the part is so small. I've searched Rennlist and nobody has documented how they've removed these broken bits.
Old 08-29-2013, 06:08 PM
76FJ55
76FJ55's Avatar
Could you slot it with a cut-off wheel on a dermal, and remove it with a flat blade screwdriver?
Old 08-29-2013, 06:18 PM
Lizard928
Lizard928's Avatar
Take a chisel and tap around the outside in an unscrewing manner, or go to sears and get their broken bolt extractors which are female (they go over the broken part)
Old 08-29-2013, 09:25 PM
syoo8
syoo8's Avatar
Originally Posted by 76FJ55
Could you slot it with a cut-off wheel on a dremel, and remove it with a flat blade screwdriver?
Yes! It worked. Thank you!
Old 08-30-2013, 02:05 AM
syoo8
syoo8's Avatar
Default This is why I am a newbie
Following Mike Frye's instructions, I tested the throttle body for leaks. Sure enough, the throttle position sensor (TPS) side of the throttle body axle had an air leak.
I decided to disassemble the throttle body to get at the two O-rings that were leaking.
Here's where my inexperience reared its head. I did not realize that the ends of the throttle plate screw had been flattened, or staked, until I started unscrewing. I didn't read about this in the other throttle body write-ups, but I should have checked. It is a little clearer in the right screw below.
The staked screw slightly damaged the rod that holds the throttle plate. My screwdriver destroyed both screws.
I think I'm going to have to give Mark Anderson a call at 928 International and buy a used throttle body.
If you are disassembling your throttle body, make sure that the ends of the phillips-head screws that hold on the throttle plate are not staked.
Old 08-31-2013, 02:23 AM
syoo8
syoo8's Avatar
Going through the engine compartment, intake runners removed, it is easier to see other (intake unrelated) items that need to be refreshed.
Name:  130829 Rear PS Annotated.jpg
My "thermo switch" had a broken vacuum attachment, so I ordered a new one. Also, the "adapter" (as PET calls it) was crusty and was obviously leaking coolant at one point or another. Might as well change the hose from the heater valve at the same time.
Old 08-31-2013, 02:30 AM
MainePorsche
MainePorsche's Avatar
How old is your heater valve ?
Might be a good time to change it out. Once you buttoned up, it's a PITA.
Old 08-31-2013, 11:30 AM
syoo8
syoo8's Avatar
My heater valve was replaced March of 2010, so its three years old+. However, it has been zip-tied for much of its life- there was no vacuum in the HVAC system until June of this year when I replaced a bunch of diaphragms. I will probably change it anyway since I have a new heater valve lying around.
Old 09-01-2013, 08:20 AM
Mike Frye
Craic Head
Mike Frye's Avatar
Scott,
That stinks about your throttle plate screws. Mine had some locktight on them to keep them from backing out, but they came out without any issues for me. The only things I ran into during disassembly and reassembly were the typical throttle issues: springs, retaining clips and tiny tiny screws getting lost.
Sorry for your troubles on that one. Are you sure there is no way to salvage it?
Old 09-01-2013, 08:35 AM
Leon Speed
Leon Speed's Avatar
These non standard size screws haven't been sourced yet I think, drill out and tap to a standard size was suggested. Then stake them the ends so that they don't come loose, or use loctite red.
Old 09-01-2013, 09:22 AM
AirtekHVAC
AirtekHVAC's Avatar
Since I have a 16v, I am late to the game on this one....great write up so far, and good job! Following with much interest.
Old 09-01-2013, 09:25 AM
depami
depami's Avatar
Scott,
Did you actually get the screws out? If so I would think this should work:
I plan to do this job soon so am very interested in your progress.
Keep up the good work and reporting.
Old 09-01-2013, 01:09 PM
PorKen
Inventor
PorKen's Avatar
Note that there are three isolators. The third is in the valley, just visible in the lower left of the second pic.
Two of the buffers are the same size. The third has a longer stud on one side to hold the IAC/ICV bracket, first pic.
Replace all three! The old one pictured will fall apart as soon as you have everything back together (BTDT).
Old 09-01-2013, 01:24 PM
BC
BC's Avatar
Clean, Clean, Clean; Powdercoat Powdercoat, Powdercoat. Order Parts.
Isn't that basically the top end refresh directions?
Old 09-01-2013, 02:52 PM
Shane
Sharkaholic
Shane's Avatar
Yep!
Quick Reply: A 86.5 Intake Refresh Picture Thread from a first-timer
