Front Evaporator Cleaning Question.
#31
I'm going to clean this area on my 91 S4. The coil and box doesn't look too bad but some cleanup will be good I know. Where is the condensate drain located and how do you clean it? Mine is not plugged but it does drain slowly so I think I need to find it and clean it out also. I've looked under the car and haven't found it there.
#33
Don't use a metal snake to clean hose out from the bottom up. You can make your way up to the evaporator and damage it or the resistor pack. Use a hedge trimmer line (the same you use for the sunroof drains) and be reasonably gentle.
#34
