Door lock vs. alarm activation
The doorlock on my 86' drives door broke. I took the doorlock from the passenger door and fitted it to the drivers door. All fine.
BUT, now, the alarm deactivates when I lock the door, and Activates when I unlock the door. Opposite function. Can i swap the wires in the 3 wire connector around to rememdy this? If so, which wires do I swap. :thumbup: |
Swap the brown/red & brown/green wires, leave the brown wire as is.
Or - swap the alarm contact part over from the original switch - its probably just fine... Alan |
Cheers! I will swap the Wires, as I already installed the locks, and as we all know, the lockarm can at times be fiddly...
Works a charm :-)
