Guess what happened 150KPa Radiator cap, and then the fans stopped working.
I believe this effect was caused by an accumulation of small "overheats". This car had intermittent fans. Either only one, or a very weak pair, or not at all. Turned out to be a ground that was disconnected, making contact intermittently as it freely rubbed against it's correct mounting bolt.
However before Terry was able to fix the intermittent fans, he did change the cap to a 100KPa. This caused a full blown overheat the next day at the RTA because the pressure was not maintained in the system. So the 150KPa cap artificially forced it not to overheat and spill its guts in the past.
Then on further inspection of the cooling system Terry noticed the radiator had a bow in it. But it is quite hard to spot while the radiator is in the car, because the transmission cooler blocks one's view to some extent.
So neither the 150KPa cap, or the radiator gave way. Ironically it was the correct 100KPa cap that caused, or rather, allowed an overheat.
One of the alleged reasons for using the short hose from the block to the heater valve is that this supposedly lets go before anything else. Whether correct or not I do not know.
It may also be be wise to replace all the water hoses if they have been over pressured- especially if they are oldish.
Phil,
It sounds as though something has been going on that should not have. The fans make a difference while idling but not at speed. If you cannot get the heat out the temperature goes up and so to does the pressure until something gives. First thing you know when the water pump fails is the temp needle rises suddenly and you quickly get an alarm. Ask me how I know?
All part of 928 ownership I am afraid. This is why I recommend going through the 30 point hit list and buy some security for 5 plus years otherwise you end up "stopping and starting".
Hope you get ti fixed quickly- sounds as though you need a radiator like Mark's?
Regards
Fred
Regards
Fred
Rennlist Site Sponsor
50/50 mix @ 15 psig boils at about 265 deg F....
The passenger side tank on the GT blew out the other day, and yep, it was pretty spectacular. Lots of steam, and the engine quit instantly (very wet distributors!). Luckily, I was at the end of my driveway, so I eventually nursed it the fifty feet or so needed to get over the little rise so I could coast to its parking slot. Jeannie shipped me a new tank and gasket, and that job is now on the priority list.
just goes to show - the 928 Gods do not spare immortals from grief- but they make it a little easlier on them by going pop on the door step!
Now when my S4 drive shaft snapped back in 1999 it went 60km from anywhere. At least when I managed to arc my battery lid shut that happened close to home as did the 3 punctures I have suffered and when I wrote off my late S4 -grrrh!
Regards
Fred
Basic Site Sponsor
Basic Site Sponsor
There are certainly exceptions....sometimes the German engineers couldn't find the forest because of the trees....but generally, they are right on.
However, since the engineers had both Behr caps (1.0 bar and 1.5 bar) at their disposal (and they used the 1.5 bar cap on the 944 series) they probably had a damn good reason to use the 1.0 bar cap on the 928.
Besides that, the 928 series has an extremely efficient cooling system and rarely overheats with all the stock pieces. If a 928 boils over....there is something wrong.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
I think you are absolutely right. However the top side blew out more than the bottom, probably because it has less force holding it flat.
I just took the thermostat out to see if there is any corrosion or blockage and this is what the thermostat elbow looks like. Coolant had not been changed in 5+ years, driven regularly but not for a far distance. So the inside of the radiator must be spectacular.
But this makes me wonder, what about all the coolant journals and jackets. If they are this packed up, then surely the car cannot be cooling effectively. Which explains alot.
Here's a pic:
Here's a pic:
The $300 used engine in the Estate suffered from this.....to the point that it ate through part of the heads...I guess it figured out it needed 2 cooling channels between cylinder 2-3???
