928 Forum 1978-1995
Sponsored by: 928 Specialists
cruise control help
Old 06-14-2013, 07:56 PM
rgs944
rgs944's Avatar
Originally Posted by John Speake
Thanks for that link. However Borland's picture is of the later type 911 part number device, which is not the same as your 928 617 127 00 part.
The principle on which is works may be the same but best to check with him first.
I will check with him. It would be nice to do this so I can eliminate the bulb control module as a problem for the cruise.
Old 06-14-2013, 07:57 PM
MainePorsche
MainePorsche's Avatar
Have you checked vacuum line status at the unit aft to the wheel ?
Old 06-14-2013, 08:44 PM
ammonman
ammonman's Avatar
Get a hand operated vac pump from your local parts house. Easy to check the vac reservoir for leaks with this tool. Connect to the reservoir and hand pump until gauge on the pump reads ~20" Hg. It should hold this level easily. If it won't hold then your reservoir is leaking.
Mike
Old 06-15-2013, 12:44 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,234 Likes on 1,236 Posts
also check the HVAC pods any that leak will reduce the effectiveness of the CC ,
and it may possibly not even work
Old 06-15-2013, 01:13 AM
77tony
77tony's Avatar
Are you running all LED's for the 6 tailights with that napa rear brake light upgrade you performed ? Try swapping in just one of your old incandescent 1157 bulbs. If that works, you can run an inline resistor and swap the LED back in. T
Old 06-15-2013, 03:32 AM
rgs944
rgs944's Avatar
I did cut off the hvac system completely for now so I can eliminate that. I feel like I am getting plenty of vac to the unit now but will check with the might vac to be sure.
Old 06-15-2013, 03:34 AM
rgs944
rgs944's Avatar
I am still running the 1157 bulbs. The reason I went to the napa tail sockets was that old sockets were losing connection.
Quick Reply: cruise control help
