Do these pictures need captions? (32V Intake Manifold Study - HP)
#391
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
While this would be great, this would take tens to hundreds of hours of engineering a variable intake manifold. I believe Greg's current setup is very well suited and designed for our application. Somewhere in here is a dynosheet showing a 50HP gain on (I think) a GTS. Keep in mind this design does not incorporate any type of variable length runner.
#392
Fuse 24 Assassin
Fuse 24 Assassin
I just had a random thought. If there is a new iteration of an intake manifold, can we please for the love of God have the ISV located somewhere we don't have to perform major surgery to replace it?
#393
Basic Site Sponsor
Basic Site Sponsor
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#394
Captain Obvious
Super User
Super User
Porsche did have a variable (two length) V6 engine that was originally developed for the Boxter and then they decided to sell the engine to Ford and use a smaller version of the M96 engine that eventually went into the 996. Mainly the Ford Contour/Mercury Mistique V6s ended up with these engines and some other Ford models too. With a manual transmission the little 2.5L V6s were surprisingly powerful. I had one in a Contour.
#395
Agreed that variable cam timing makes runner length changes almost moot. And turbo charged engines make variable runner lengths just extra weight.
However, this thread is about 928's.....30 (plus) year old engine designs.
The 928 5.0 and 5.4 engines engines were far, far from being optimized in the form that was delivered. The delta in runner length and individual cylinder filling capability is extremely high. I understand that they were trying to "package" many things in a fairly small area....which is part of what has made building a better intake so time consuming. While I can (and have) cobbled up prototypes for testing, optimizing each little detail has been a real challenge.
Personally, on the stock intake, I consider the flappy in the intake to be more of a "patch" than anything else....I think the engineers were sitting around asking: "What can we possibly do to help this crazy intake design function better?"
The engineers had the access to a single plane long runner manifold already, but it didn't meet these requirements. I'm talking about the cast FIA Group B S3 manifold. I'm guessing that the Group B manifold didn't meet their low rpm torque requirements, which in turn were driven by the requirement to use the same intake for automatic and manual cars.
I believe that for a manual transmission only 5.0l car, the single plane Group B intake would've been cheaper to make and overall probably a bit better. But that I believe wasn't allowed by the requirements.
For a hot rodded normally aspirated manual 928, of course headers, high overlap cams, high compression, and long straight runner single plane intake (preferably with ITBs) is going to result in a more powerful, faster, and sportier car than anything that the factory contemplated in the 1980's.
