928 Forum 1978-1995
Sponsored by: 928 Specialists
Tensioner Bad?
Old Apr 8, 2013 | 10:09 PM
  #31
ROG100's Avatar
ROG100
Basic Sponsor
The early bolt was a real small diameter and no longer available.
I had some made with a stronger steel and they are $28.50 each.
Old Apr 8, 2013 | 10:49 PM
  #32
PorKen's Avatar
PorKen
Inventor
OMG. There is so much wrong in that pic.
Should be a special shoulder bolt, not a regular bolt - 928 105 570 03
Get thee to a PKT!
Old Apr 8, 2013 | 10:51 PM
  #33
SeanR's Avatar
SeanR
Get thee to a PKT!
Good picture Ken, I saw the OP's picture and just shook my head.
Go with the Porken Tensioner.
Old Apr 8, 2013 | 10:54 PM
  #34
ROG100's Avatar
ROG100
Basic Sponsor
Ours is a shoulder bolt.
Old Apr 8, 2013 | 11:13 PM
  #35
vanster's Avatar
vanster
For some reason I feel a lot better as I just put the bolt back in that I took out.
Some cleaver PO's mechanic I assume. Now I will take the new water pump off and drill out the old bolt ( I will find a drill press and wait for the new bolt first)
Also the tensioner looks marginal. A PK is in my future as a bolt and a few other bits from Roger.
Thanks to everyone
Van
Old Apr 8, 2013 | 11:46 PM
  #36
the flyin' scotsman's Avatar
the flyin' scotsman
the newer style water pumps come with a new shoulder bolt.....not the older style?
you dont need a shoulder bolt with a Porkensioner.......another big plus
Old Apr 9, 2013 | 12:09 AM
  #37
Mrmerlin's Avatar
Mrmerlin
Team Owner
drain the block before you try to remove the broken bolt. If your not fitting the PKtensioner now.
OTOH The WP can stay in place,
if your fitting a PKtensioner.
you wont need the new shoulder bolt .
you will have to plug the WP,
SO in that case you dont need to remove the broken bolt just add a plug to the remaining hole.
Old Apr 9, 2013 | 12:33 AM
  #38
the flyin' scotsman
if you need a plug shout out as the Porkensioner kit comes with both older and newer WP sizes......I and prolly a great many have new plugs in their spares bin
Old Apr 9, 2013 | 12:42 AM
  #39
PorKen's Avatar
PorKen
Inventor
The remaining bolt will probably come out easily with a left-hand drill bit. No need to remove the WP.
Old Apr 9, 2013 | 01:19 AM
  #40
Mrmerlin's Avatar
Mrmerlin
Team Owner
I hope this repair works out perfectly
