How does lots of oil accumulate in the intake?
I've had similar problems with my '85 Euro S. Once I noticed that using high octane fuel eliminates extrem oil consumption, I re-programmed my injection system (it's a Megasquirt) and now all problems are gone. I guess you cannot re-program easily, but at least, I've prooven that pinging of the engine was the cause. You could have the same and tehre could be multiple reasons for pinging: wrong temperature rating of plugs, excessive carbon built up, too high CR etc. etc. You could try the same as me: buy more expensive fuel with higher octane and see how it goes...
Someone please correct me if I'm wrong, but doesnt the valve covers vent into the intake... Not uncommon to find oil accumulating in the plenums, throttle body, etc... I think it was because of the dreaded EPA - I hate those guys! I'm not sure if it actually HURTS anything, but oil in the mix just doesnt sound righ to me... If I ever do a top end refresh I'm definitely going to install a sharkvent or similar device.
When I installed my turbo, one of the modifcations I had to do was change the PVC system. One of those changes was to remove and plug the rubber line running from the left side of the oil filler neck (as you are facing the car) to the left side of the rubber MAF boot so that the crank case would not be pressurized when under boost. This line has a Y or T and picks up the rear cam cover vent as well. I plugged this line, and vented the system differently. This elimated ALL of the oil I was seeing in my intake and throttle body bowl. It is bone dry. This is on an 87.
Basic Site Sponsor
Basic Site Sponsor
I make these to fit under a stock late model filler neck, which has the "baffle" built in, so I'd suggest using the stock baffle on an early engine, too.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Sharkaholic
Frank does it look like this?
If so that is the oil control plate that 928 Intl sells, I added it with the stock baffle and used Drei Bond to seal it all against leaks.
Shane, Yes that is it. Greg, thanks for the tip. I have already made the gasket for both sides. So I see it like this, first goes the first gasket then the baffle in the pic above, then the stock baffle with new gasket/seal, then filler neck. Greg, did you ever come up with pricing for your new solution? I read the thread but don't remember. Would it be better $$$ spent then powder coating the intake tubes? I hate the way they look.
Thanks,
Thanks,
Basic Site Sponsor
Basic Site Sponsor
If you turn the engine upside down (with the pan off) and look at this area, with the 928 International version in place, you can see a direct path to the bottom of the oil filler neck. Some of the oil that is "slung" off of the crankshaft blows right by this style baffle and hits the bottom of the filler neck....no choice.
This new piece completely blocks the direct path and make the oil/air "mixture" turn a corner to even get inside. This first "turn" separates a large amount of the oil, from the air.
Once inside, the oil/air mixture must turn around a built-in internal baffle, further separating the oil from the air. The trick isn't so much the baffle but the reduction of velocity. The oil/air mixture must slow down, for the oil to "fall out" of suspension.
We did a fair amount of testing and research.....as we always do. Turns out that you have to be careful. Too many baffles, inside, speeds up the air velocity, which actually keeps the oil from falling out of suspension.
It works!
This baffle is the first one that we have made and is a significant improvement to the nice working simple piece that 928 International offered.
We did a fair amount of testing and research.....as we always do. Turns out that you have to be careful. Too many baffles, inside, speeds up the air velocity, which keeps the oil from falling out of suspension.
It works!
It works!
I ran an S4 this past summer minus this (not on flucking purpose) and found out exactly how bad the windage/oil ejection was. 1500 miles and 5 quarts. I won't admit how this happened but let's just say put something in that oil fill neck.
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
I made this new version because I was still getting a large amount of oil from the filler neck area, using the original 928 International design.
I'm not saying theirs is bad...it was a great idea and worked better than just the stock parts.
This is just an improvement.
Archive Gatekeeper
Can you put one on your desk for me?
Basic Site Sponsor
Basic Site Sponsor
