Door panel removal
Door panel removal
How do you take the little plastic door lock trim piece for door panel off?
Like Mike said, take the center **** off and then use your palm to unscrew the big part.
As Mike stated the center of the lock **** needs to be removed. it is merely pried out of the lock **** using a tin took to fit in between the **** and the edge of the center cover. Then remove the screw found underneath it and but the **** off. Once the **** is removed the outer ring on the door panel lock assembly threads off. I believe it has a few pin holes for a tool to interface with it, but I have been successful in just palming them and rotating them by hand to remove them.
Thanks guys, previous owne used thread lock....not sure why?
Doing a drivers side window and window trans plastic guide is broke !!! Stuck till I get a part.Can you get the plastic guide seperate ?
Order it from 928 Intl.
Team Owner
there is thread lock applied to the lock **** screw from the factory .
NOTE dont make the lock surround very tight when you put it back together as this can cause the lock mechanism to bind,
just past snug will work,
same goes for the lock **** screw just make it snug dont keep cranking it tight.
If your replacing the plastic guides make sure to replace both top and bottom,
so the window will function properly
Just a reminder, but be careful not to forget the two 10mm bolts that secure the door panel just inside the parcel compartment. They are often forgotten and the end result is a mangled up door panel.
Bought car from a shop ....they hacked car up . Taking more time to fix the things they did then actual problems with car .
I got all of the bolts but couldnt get the trim piece to unscrew . Thanks guys . It amazes me how nice everyone is on here . Glad to be part of it .
