928 Forum 1978-1995
Sponsored by: 928 Specialists
window motor connector removal
Old 01-20-2013, 04:20 PM
Tampa 928s
Tampa 928s's Avatar
Default window motor connector removal
I am having a hard time removing the connector from the window motor. The plastic tang is not moving in or out before I break something can anyone advise the way to do this?
The window is dead swapped switch seems to be the motor, if I remove the star bolts will the whole thing come apart and spill parts all over the place?
Old 01-20-2013, 04:26 PM
mickster
mickster's Avatar
Not sure if it's the same as 91 but I just had to wiggle it slowly. I removed the outer and then had to untwist the worm gear. Just be careful not to let the window come off track and break! I think there's a write-up. Will search.
Old 01-20-2013, 04:33 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,541 Likes on 1,228 Posts
Unless the connector for the motor changed between your year and '91, I don't recall there being a tang on the connector, or if there was I got lucky and squeezed in such a way that they just popped off. Here are two shots of a '91 motor connector.
EDIT: LOL, lots of advice on the '91 motors today.
Old 01-20-2013, 05:14 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,234 Likes on 1,236 Posts
spray some WD40 on the connector,
then wiggle it a bit,
then pull it straight out
Old 01-20-2013, 05:51 PM
Tampa 928s
Tampa 928s's Avatar
Go figure it is now working I took it apart and the rear bearing is cocked and the armature is worn on a few spots. I need to look for a replacement!
Old 01-20-2013, 09:32 PM
Bilal928S4
Bilal928S4's Avatar
Roger has new ones at a very reasonable cost. Sometimes same or nearly what a used one sells for.
Old 01-20-2013, 11:05 PM
Mike Frye
Craic Head
Mike Frye's Avatar
I put mine in a drill chuck and spun the armature against some 400 grit sandpaper to clean it up. Works like a champ now.
Old 01-21-2013, 01:17 PM
Tampa 928s
Tampa 928s's Avatar
Default WTB Pass Window Motor
Well the inevitable question does anyone have a passenger side motor for sale?
Old 01-21-2013, 01:52 PM
mickster
mickster's Avatar
I'd get the one Roger is offering. I did find a used one but had to basically rebuild 1 from 2.
Quick Reply: window motor connector removal
