Initial startup and Lamps check/pod lights 87 s4
I cant get power to the light on my "O"..odometer reset switch. When i push the button the odometer resets. When i have the parking lights or headlights on, i would assume the **** should illuminate.
The LED checks good from a seperate power source.
I'm tracing the circuit on the diagrams now but any ideas in the meantime
...uh...i had forgot to hook up the dimmer.
I just bypassed it with a small jumper wire and all is good again. The dimmer is obviously in line with the back lighting on the pod...HVAC...clock..etc...
now to solder in the resistors ...although i like it bright it may be a bit too bright at night.
Looking good, Tony. The LEDs are a huge improvement, especially in the cluster.
BTW, the dimmer modules are really close to done. I'm making some enclosures tonight, in fact. I really think I'm finally about one to two weeks away from shipping a few.
If you you plan to use one of the dimmer modules, then while you've got your cluster off, run a brown ground wire (and maybe a few spares; they're handy to have around when installing new stuff!) to the grounding point (MP IV) under the left side of the cluster. Or maybe on your MY, it's easy to do that later, too. For dimmer module installation, you'll need to get to the rheostat connections, and you'll need a ground wire. As it turns out, it'll actually be easier on the old rheostat models (-89) than the newer ones (90-) due to the use of readily available quick disconnect terminals on the old rheostats.
is it to establish a preset level of brightness when the lights are turned. from that level the dimmer would take them dimmer but never any brighter.....i think that is the reason.
with my lights off, the only switch lit is for the headlights....as it should be. I dont have any other "residual" voltage that would cause any other pod light to light up or faintly glow.
my hazard unit (87s4) has two black/blue wires...do i place a resistor on both.
thnx
hi Ed...can you clarify the purpose of the resistors on the pod switches.
thnx
thnx
In the case of any switches with two BK/BL wires, the resistor goes between the switch contact and the two wires (the two existing wires are just daisy chaining to elsewhere and you want to preserve that connection without any resistance).
