84 Euro Info Help
Does the ABS fault light come on as soon as engine is started, on only when car moves ?
There are two relays in the box under the inner wing liner that can fail if the first fault is the one... plus the relay on the CE panel.
A rolling fault is more of a problem as the wheel speed sensors for your 84 are NLA.
Peter, The ABS fault light in the pod may be out... If you start rolling the car and the ! fault light comes on at around 5 mph and your ABS pod light is NOT lit up then your ABS sensor leads / grounds may be disconnected (common problem - they get brittle & break). Jake and I fixed mine and its pretty easy actually. If this turns out to be the case - check out 928BuckeyeLandsharks website for pics. Cant comment on LED lights in the pod... thats past my expertise level
