14 pin connector ''pinout''
Electron Wrangler
1987 14 pin connector:
1 Blue - Alternator 61/D+
2 Blue/Black - Oil Pressure Sender (W)
3 Blue/Yellow - Water Temperature Sensor (G)
4 Blue/White - Oil Pressure Sender (G)
5 Blue/Green - Water Temperature Sensor (W)
6 Green/Blue - Oil Level Switch
7 - Unused
8 - Unused
9 Black - AC Compressor Clutch
10 Green - Intake Temperaturre Sensor
11 - Unused
12 - Unused
13 Brown - Ground for intake temp sensor
14 Yellow - Starter Solenoid
Alan
7 - Unused
8 - Unused
11 - Unused
12 - Unused
Alan
Last edited by Alan; 05-02-2014 at 08:40 PM. Reason: Swapped 3 & 4 - because they were wrong
Alan,
Thanks for that, after I posted I kept browsing different threads and ran across Bill Ball's pin out in this thread:
https://rennlist.com/forums/928-foru...d-issue-4.html
87-88 are the same. 89+ has an additional wire (pin 7)
TOP (male pins)
PIN - WIRE COLOR/STRIPE - Function
1 - Blue - alternator exciter
2 - Blue/Black - oil pressure
3 - Blue/Yellow - coolant temp
4 - Blue/White - oil pressure
5 - Blue/Green - coolant temp
6 - Green/Blue - oil level
7 - EMPTY except 89+ Brown/Red - oil pressure
8 - EMPTY
9 - Black - AC compressor clutch coil
10 - Green - intake air temp switch for fans
11 - EMPTY
12 - EMPTY
13 - Brown - intake air temp switch for fans (ground)
14 - Yellow - starter solenoid
It seems your pin outs match except for 3 & 4, so which pin out is correct?
TOP (male pins)
8 - EMPTY
11 - EMPTY
12 - EMPTY
Electron Wrangler
Yes it was my mistake - 3 & 4 were swapped (now fixed above for clarity).
The colors and functions were correct, just these two positions were wrong (3 <-> 4).
Strangely Bill's table looks very familiar to me - I think I provided it originally... makes my error even worse I guess...
Alan
Alan
