Nice center console solution in a 1995 GTS, as for sale in Austria.
#32
I want to do the same thing Jerry. I actually bought another center to experiment with...although it is way down on my list right now....
I planned on lowering the ac head, and the central indicator, like what you have done, of course, mine would not look as good
#33
Jeff and Ron. My basic conversion in black leather into a plain vinyl center console with your double DIN Nav unit and your HVAC and ! panel for either the auto or the manual shifter, including a matching leather boot, is $800 plus shipping. There will be some wiring issues when you get it back since the HVAC unit moves down to a place where the connector will not fit, so you have to wire each pin individually somehow. You will need to send me the complete center console and the air vent louver devise becaue it too has to be modified. My conversion also includes a little devise to reconnect the air outlet back to the air source so the air does not just blow around under the dash when the outlet is moved from the console to the upper insert resulting in the change of the outlet angle. Any console restoration is extra, but some of it comes with the conversion, such as re-establishing the upper two mounting points.
We will need to discuss some of this a little further, particularly the timing, and we can do that by phone and/or email.
jfeather@bresnan.net
970 243 8513 off., or 970 243 3568 at home evenings and weekends. Don't say you have anything to do with one of the current campaigns if you call because we will hang up on you.
#34
Basic Sponsor
OOPS! I should have posted that in this small business membership.
ReDesign by FEATHER
by Jerry Feather
Producer for 928 of:
-Hatch Latch Receiver Liner--All Versions
-Replacement Heavy Duty Spare Tire Cover
-Flush Center Console Conversion
-Cowl Cover, Cowl Seal, & Shell Stickers--All versions
(RHD included)
-Aluminum Gas Cap Ratcheting Pawl
ReDesign by FEATHER
by Jerry Feather
(RHD included)
#39
Here you go
Basically I got two other vents (one upper one lower) and then snipped rear plastic bar on the back side so they operate independently left from right. Replacing the center **** thingy so there is one for each side. The center vane is super glued in that position
#42
I contacted Dr. Konradsheim who is selling this car among other 928 and other Porsches (see my post #1).
And although I made him aware that I am not interested in buying this particular car and just curious about any background information about this very professionally done center console conversion, I was very impressed to receive an immediate instant reply with the following information - for which I have persmission to provide it here on Rennlist:
" .. this work was done at Becker, when the car was driven by the ceo of Becker, therefore the solution is pretty perfect "
Explains a lot to me, and nice to know info.
#43
Its also cool that the CEO of Becker was driving a 928 by choice in 2002, even though it was 7 years old (guess based on the age of that PCM version).
#44
#45
Jerry:
Looking at the INE-Z928HD with these case and face specs:
Dimensions
Din Size: 2
Chassis Size (W x H x D) mm: 178mm x 100mm x 165mm
Chassis Size (W x H x D) in: 7'' x 3-15/16'' x 6-1/2''
Nose Piece Size (W x H x D) mm: TBD
Nose Piece Size (W x H x D) in: TBD
Do those dimentions cause any headaches?
Dimensions
Din Size: 2
