My mysterious interior
Here is a shot of my interior:
http://i199.photobucket.com/albums/a.../interior1.jpg This appears to be a mix of Pearl White and Blue. Some say that the Pearl must have been a dye job done after the car was built. Others have said that this could have been a special order interior. The label in the back of the car notes that the exterior color is L347 which is Dunkelblau and reports the interior simply as "72." PET has listings for various interior components where the colors are a combination of three characters and not two. Pearl White is listed, as is Blue. Of course, with the possible exception of the door cards, I don't have any components that are two colors at the same time. I would not therefore expect PET to have codes for a blue/pearl combination. This is not a matter of great importance to me, but I am curious and would like to know if my girl is a dyed hussy or her colors are natural. Any insights are appreciated. Thanks |
I like the look, although it must be hard to keep clean. It looks like you have scuffing next to the seat switches - but I don't see a previous blue dye showing thru FWIW
Have someone run a vin check; is there a label in the hatch area with the color code and option codes?
It looks factory !! the upper door window trims are very hard to change and they are white ! Someone special ordered that combination plus leather dash and the 5 speed :)
Redying the WHOLE seat is a bit of work. If it is redyed/painted, you'll almost undoubtedly find telltales around the hog rings holding the seat together, or under the rear seats where they are glued down. Quick check is with a mirror under the seat, probably easiest from the rear, looking for either hog rings with the current color, or edges of the surface material that are still an old color.
No answers for you, but it is good looking interior IMHO....
Originally Posted by James Bailey
(Post 9925974)
Lots of possibiites. I'd go with Jim's special-ordered story, adding to a car's pedigree a lot more than my redyed or donated bits option. |
Here is the label from the back of the car. I have no idea what "72" means in the line for the Paint Code/Interior.
[IMG]http://i199.photobucket.com/albums/a...ps60d68c4e.jpg[/IMG] |
Originally Posted by Eplebnista
(Post 9926038)
For later MY's there is quite comprehensive list in 968 forum. 928 used same codes but there might have been other codes which were 928 specific. But all those codes are different than what was used in early S4 and older models as all interior colors available are also different. |
It's a shame no one has been able to 'crack the code' on interiors. Sure looks nice though! I've always liked the two-tone interior look, don't know of any car with this even as special order after the mid-80s.
Very nice combination IMHO. Mine is all white leather interior, including the hurn push, but it does not have an option sticker in the back. The Invoice just says 'Leather to Sample' for the interior. And yes it is hard to keep clean, and its very glary in bright sunlight. See P110 in the Brian Long 928 book.
jp 83 Euro S AT 54k. |
Originally Posted by jpitman2
(Post 9926646)
Since an owner could order anything there was no easy way to provide option codes for all those permutations. Could have been in a special build instruction tied to the "Leather to Sample" code. |
4 Attachment(s)
(Post 9925849)
http://i199.photobucket.com/albums/a.../interior1.jpg This appears to be a mix of Pearl White and Blue. Some say that the Pearl must have been a dye job done after the car was built. Others have said that this could have been a special order interior. The label in the back of the car notes that the exterior color is L347 which is Dunkelblau and reports the interior simply as "72." PET has listings for various interior components where the colors are a combination of three characters and not two. Pearl White is listed, as is Blue. Of course, with the possible exception of the door cards, I don't have any components that are two colors at the same time. I would not therefore expect PET to have codes for a blue/pearl combination. This is not a matter of great importance to me, but I am curious and would like to know if my girl is a dyed hussy or her colors are natural. Any insights are appreciated. Thanks Another 1986.5 shares your car's combo in burgundy/pearl white. Picture courtesy of davek9. Enjoy your gem. Steve |
For my seats, all three tags matched: one under the seat, the other on the inside of the leather and the option code sticker in the rear hatch. Next time you have one of the seats out, will be easy to tell.
I also have the same pearl white interior, but with black dash and carpet. I have long suppected it was a special order interior, but never took the time to look it up.
