looking for pistons, 1982 928s
i am looking for a set of pistons, getting the engine rebuilt, several of mine were damaged, missing part of piston that separates rings, i think it uses a 97mm piston, can the block be bored out to go with the larger pistons
stephen
stephen
If it was running with one or more broken piston lands and/or rings, seems really likely that the bores sustained some damage too? Given the costs of components, getting a used shortblock might be the way to go. Boring is not an option, the bores are coated/sleeved.
Man of many SIGs
Broken lands (the bits between the rings) don't necessarily mean the bores are scored or scored beyond use. Big scratches are still scratches. I've used a block after finding broken lands. No issues with that.
The blocks can be bored. I've had this done. It may not be cost effective compared to getting another used block. Going bigger sounds good but you'd be better off getting a 4.7l block for that. Or 5l block. Then there's matching the pistons to the heads and cams which may mean notching, but I doubt it and really don't know for those combinations.
Your engine should be a 4.5l version so 95mm pistons. These are commonly available. The trick is the tolerance group. You'll find a 0, 1 or 2 stamped on the block above each hole and on each piston. That's the tolerance group number. Consult the manual on this, too. 2 is the biggest and you can go with a bigger piston due to wear but never a smaller one. I suggest getting a few more than needed and doing test-fittings to find the pistons that work well. Takes a sensitive hand to feel what's right.
the engine is a 4.7, block and heads have already been done, pistons measure 3.816"s, having trouble finding pistons, was looking for other options
If it is a Euro S then it is 97 MM and more rare in the USA. Also higher compression and manual ignition timing adjustment which could explain broken rings.... too much advance, poor fuel, too much bwaaah !!!equals shattered rings. And as noted the blocks can be bored and honed oversize, no sleeves no coating just an all alusil block. But never ever use a simple bottlebrush hone on a drill motor like you would a old Chevy
Steve,
I have a complete set of 97mm pistons from a 1983S (US). Car had about 60k miles on it, before I took them out. They're in a good shape.
Send me an email if you're interested: psdj46@gmail.com
Peter deJong
'83S (RIP)
'90 GT-twin turbo
Peter deJong
'83S (RIP)
'90 GT-twin turbo
car is a euro, had so much base pressure it blew out the seals, timing belt was split in two, like two belts on one set of pulleys, pistons were rubbing on one side, car has been in shop since dec , ready to get it back, only one machinist in town that will do european motors
Sorry but you are screwed !! You ONLY bore hone blocks AFTER you have correct pistons of the size you bore and hone the cyinders for . Friggin idiots !!!!! Many of the oversized pistons have been unavailable for years !! This stuff is pretty easy yet so many manage to screw it up.....
