928 Bellhousing Bolts
Or just take the motor out with the bellhousing then disconnect and support the torque tube by letting it rest on the exhaust, and support the exhaust system with rope from the header to crossover connection... the exhaust system is strong enough to support the torque tube. This was much easier.
Rest in Peace
Be careful when you double up wrenches, do not let a finger get into the open end of the wrench because if it slips and turns it will break that finger, I have seen it happen, or rather heard the scream as it happened.
Basic Site Sponsor
Basic Site Sponsor
Just kidding, we torque them, to spec., always.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
I torqued them to spec too. Good-n-f'ing tight spec cause I didn't have a torque wrench that would fit in there. Still tight too.
For torquing stuff like that's even harder to reach, you can measure the length of any wrench (including an open ended one) and then use a hanging scale (fishing scale) to apply the correct force.
I'll add one of these wrenches to my next shipment of tools from the USA - I need to drop the torque tube on my '87 and this will come in handy.
Don't forget to install one of the better aftermarket shifter linkages while the motor is out! It's somewhat more accessible while the motor is out.
We use one of these with bent 19mm end, works perfectly. Set is around $150 but its best money I have ever spend on tools. Sizes are 10x11, 12x14, 13x15, 16x18, 17x19 and 22x24mm and lenghts between 40 and 50cm.
Supercharged
Having just done this job, I found the "long-reach" harbor freight tools box wrenches reach perfectly. Throw a second wrench on it to extend it and crack! done.
Couldn't get the upper bellhousing bolts... i know that if i start to get pissed off i start breaking things and throwing stuff around, so pulling the engine probably avoided me breaking a part because i was pissed.
The link isn't working for me ... can you say more about this set.
The EZ Red kit doesn't have the 22/24 that I need. Your kit ( I mistook it for the EZ Red ) does.
Just used the EZ-RED wrench. It does make childs play of those upper bolts. As long as you have your wife handy to get the bolts started ;D or someone else with small hands.
What's the torque spec for those four bolts? Looked through the manual but couldn't find it. It's been a long weekend. Thanks
