Car Died Today While Driving Down The Road
Fuel pump fuse is good. When I jump fuel pump relay 87&30 I get I thunk sound from the back (fuel tank) not a click from the fuse panel. Almost like fuel pump wants to turn on but doesn't, should be humming but isn't.
I had that happen to an 84 that sat for 2 years with old fuel, Pump was stuck and a new one fixed it, The old pump was new but was stuck, just made a clunk sound every time I jumped the relay. Try to reverse flow it, see if anything comes out. How did your internal tank screen look like?
I called my tech and he's going to pick it up and look at it next week. Was hoping it was a fuse or relay issue. Thanks for everyone's help, you all are the best! Will update you all with the outcome. Who all is coming to the Frenzy, can personally thank you there!
Rennlist Site Sponsor
Don't assume that a new fuel pump will solve the problem. If the hose between the internal fuel pump and the fuel tank outlet has disintegrated, the pieces will jam the external fuel pump.
It shows on the '86 wiring diagrams.
Easy to check - look for the wires going into the tank fitting. If the wires are dead-ended near the external pump, you don't have the internal pump. If the wires connect to the tank fitting, you should have the internal pump.
To all that sent diagnostic tips thank you. As promised i would update everyone with the actual problem when found, it was a defective fuel pump. The fuel pump was just replaced a few months ago (Bosch unit), doubted it could be the problem but it was. So i'll now have my tech replace the fuel gauge sending unit at the top of the tank since my fuel gauge isn't reading properly. By the way my tech covered the pump labor and tow bills. First class operation!
I removed mine the day I saw the thread about the failure and subsequent fire. It looked cool, but a non burned up 928 looked even cooler in my garage.
