GTS dripping water near catalytic converter
Drove the car tonight and when I pulled back in the garage i could hear hissing, like water hitting a hot object. So, I looked under the car and there is water coming from somewhere near the catalytic converter. Sometimes it get vaporized into steam and sometimes it falls to the ground.
Any suggestion on what's going on?
Water is a byproduct of combustion, in fact the amount of water produced per cycle per cubic inch of displacement is roughly 1.24 times the weight of the fuel injected into the air mass. In other words, i wouldn't worry about it.
Water from combustion shouldn't be dripping externally from the cats.
I would lean toward the HVAC drain but that shouldn't drip directly on the exhaust. You might want to check the HVAC drain to be sure it isn't partially plugged and causing moisture problems elsewhere, especially the CE panel.
Team Owner
to get to the drain and I dont know why you need to,
it passes through the chassis at the bottom of the HVAC unit inside the car,
the water drips onto the exhaust pipes and sizzles off.
The water is coming from the HVAC system,
every HVAC system will make a small puddle of water if the system is used in a humid environment.
