928 Forum
Sponsored by: 928 Specialists
poor running '85
Old 09-29-2013, 10:27 PM
  #106
Pfc. Parts
Originally Posted by byrdman454 View Post
From the Rennlist search...
The Ford Motorsport 24# injectors are a direct drop in for the 85-86 32V motor. The o-rings do not need to be swapped.
Part Number is 9593-A302.
Did not find any new ones except one set on eBay. The rest are all remanufactured.
Mike I wasn't able to find this exact injector but Summit Racing offers an alternate part, TFXÖ, 24 lbs./hr., 14.4 Ohms Impedance, 12 V.
Anyone know if this is a reliable replacement for an 85?
http://www.summitracing.com/parts/tf...view/year/1985
Pfc. Parts is offline
Old 09-30-2013, 08:49 AM
  #107
John Speake
John Speake's Avatar
I think the 85 32v needs the barbed top on the injectors ? (same as 84-86 16v cars)
John Speake is offline
Old 09-30-2013, 02:06 PM
  #108
Pfc. Parts
Not sure what you mean by "barbed top" John. I know the 32v injectors have a slot cut in the top for the rail clips. Is this what you mean? There's no hose barb on these, they have O rings.
Old 09-30-2013, 02:12 PM
  #109
76FJ55
All 32V cars run the injetor rails directly on topn of the incectors with the O-ring seal and clip holding the injector to the rail. The barbed hose fittings are only on 16V car.
76FJ55 is offline
Old 09-30-2013, 02:18 PM
  #110
Pfc. Parts
The question remains as to whether these Summit Racing injectors, which they claim directly replace the injectors Mike cites, are really compatible? Just hoping since a complete set is running about $350 and I think I'm going to need to replace mine very soon.
Old 09-30-2013, 02:28 PM
  #111
John Speake
Ah, OK, my bad, sorry for the confusion
Old 09-30-2013, 02:38 PM
  #112
Pfc. Parts
Imparting knowledge is *never* bad John. Thank you for taking the time to read and respond.
Old 09-30-2013, 03:07 PM
  #113
76FJ55
I am running the M-9593-AA302 ford injectors. The AA designates that it is the EV6 style all plastic body. I no longer see these listed in Summit but you can still find them on Amazon and the like. these are almost direct replacements. The need to have the clip groove cut in the bod to accept the rail clips. Search should find threads referencing the mod required.
76FJ55 is offline
Old 09-30-2013, 03:22 PM
  #114
Pfc. Parts
No problems with clearances needed for the EV1/EV6 adapter?
Old 09-30-2013, 03:30 PM
  #115
76FJ55
the M-9593-AA302 is actually an EV6 all plastic body injector with the EV1 style connecter so there is no adapter necessary.
76FJ55 is offline
Old 09-30-2013, 03:43 PM
  #116
Pfc. Parts
Thanks *very* much Simon, that didn't jump out in the research I did, I figured it was an adapter.
So no clearance issues, compatible and about $100/set cheaper than the Summit set. I think I can manage cutting the grooves
Best Regards,
Old 10-10-2013, 10:58 PM
  #117
Pfc. Parts
Originally Posted by Podguy View Post
Then there is putting on a pressure gauge on the rail and checking your pressure. Does it hold pressure after you shut it off.
Does anyone know how long the gauge should read pressure after ignition off? If it fails this test, what would be the diagnosis?
Old 10-11-2013, 12:18 AM
  #118
76FJ55
Per the manual it should maintain a minimum of 1 BAR at 20 minutes. If it drops below then you need to determine where the pressure is bleeding down.
Leaking injectors, leaking diaphragm on the FPR or Dampers, bad check valve at fuelpump…
76FJ55 is offline
Quick Reply: poor running '85
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
