New Product: Precision Motorwerks Crankcase Ventilation Kit
#31
Basic Site Sponsor
Basic Site Sponsor
Seems like as soon as the manifold was to see pressure, my stuff would blow up like a balloon.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
#32
Administrator - "Tyson"
Unless you route the output from your separator to the inlet of the compressor (turbo or supercharger). But if your compressor intake sees any significant amount of vacuum, that might not be good either.
What did the 944 Turbo race cars that you worked on do with the breather system?
#33
Basic Site Sponsor
Basic Site Sponsor
That's why boosted production cars have check valves to prevent the boost from entering the crankcase breather system.
That's probably why I never really "freaked out" about all the oil in the 928 intake system. Seemed normal.
Hell, if the glorified lawnmower engines and the fastback Audi's all had oil in the intake, why wouldn't the 928 engines?
#34
Same for my SAAB, the Audi's........
#35
Seriously though, this is one of those things that amazes me about some of the core members of the 928 community-continually improving a car that hasn't been in production for 17 years-almost the same amount of time as its lifespan. Incredible.
#36
What's so bad about improving it? The investment into improvement of these cars, lists/forums, and events is what keeps these cars going. Just look at how little it takes to write these cars off cause they're technically worth about the same as a Corolla. If it weren't for the stuff i mentioned, these cars would be rare, and ironically probably worth alot more too. Funny how that works out eh?
#37
Who said it was a bad thing? Just an observation comparing the 928 to other cars.
I'm actually looking into an improved air / oil seperator system for the Jaguar and SAAB.
034 Motorsports sells such a kit for the 1.8 turbo VW / Audi crowd.
The Corvettes I prep / work on at the track all have improved breather / seperator systems since the stock cannot handle track use without blowing oil smoke out the tail pipe. Well, except for the factory dry sumped models.
#38
'92 ROW = early '93 US. '92 has block halfs mounted together with studs and nuts while '93-95 use bolts. Also pistons are different between them IIRR. Difference isn't large and they are interchangeable.
#41
Greg, this thing looks awsome. Why leave out the earlier 85/86 32v cars. I am already seeing an inssue with just 1300 miles on rebuilt engine. Puff of smoke when you nail it and small (maybe 2tbs) of oil in the valley.
#42
Archive Gatekeeper
My late 93 U.S. GTS engine (85P00656) had girdle bolts, but it had the 'early GTS' breather set up. No idea about which elbow subtypes were where on the driver's side valve cover, but the engine sure consumed a lot of oil before I killed it.
There are at least 2 iterations of the breather setup on GTS's. The OP's '92 and my '93 had an '08 filler neck, and the 928 107 312 00 hose running from the cam cover to filler neck as well:
'08 neck:
Note the bolt/plug/thingee molded into the nipple on the base, to block off one of the outlets:
Pretty sure that both the -08 filler neck and 312 hose are NLA.
I ended up using the -08 filler neck on my stroker, as it was a convenient way to re-route the breathers as Greg intended.
Just for completeness/crossreferencing, Ed Scherer made a nice post about valve cover breather elbows here:
https://rennlist.com/forums/928-foru...-variants.html
'08 neck:
#43
Basic Site Sponsor
Basic Site Sponsor
Didn't leave them out. I'll get to them. Time and money to invest in products is the limiting factor.
#44
Basic Site Sponsor
Basic Site Sponsor
'08 neck:
'08 neck:
So that is the 1992 and "early" 1993 version of the breather system. Note that the filler neck has an unrestricted "upper" hose fitting and there is a hose that runs directly from there to the valve cover. They were venting the crankcase directly into the valve cover!!!! (This is very significant, as you study what is happening). There was a single hose hooked to the intake that ran from a restricted valve cover elbow.
Talk about building crankcase/head pressure! A V-8 engine with all the breathing through a single 6mm hole!
Got to love that bolt blocking off the lower port!
Mid 1993 added the other breather elbow on the driver's front, superceeded the passenger rear breather elbow to the non-restricted version, changed the filler neck to a restricted version (and plugged the lower port with plastic, instead of a bolt), added the cross-over hose, and added the hose that runs from the oil filler back to the "Y" connector.
Truthfully, I thought that I had a pretty good idea of what Porsche had done and why they had done it, right up to the point where I ran Andy's engine at WOT above 5,000 rpms and saw what happened after 30 seconds of running.
I literally then brought Andy's engine back here and just stared at it, trying to figure this all out, for about 2 months. While I knew that the only solution, for his engine, was to "remove" the oil from the heads, I figured out how to ventilate the "street engines" at the same time.
That is this new Ventilation Kit.
