will cranking the engine.........
With no fuel or spark ( plugs out). Build up oil pressure? I just installed the new Roger starter and wanted to "prime" the motor with oil. But pressure does not seem to build.....
Yes, it should. It may be that the gauge doesn't engage until the engine's running, though. Some of the other indicators certainly wait for "running" before showing a value. That would keep the car from reporting a low pressure fault at every startup, I think.
Yes, I've done that. I used a compression testing gauge with a spark plug adapter that fit in place of the sending unit.
It was quite confusing until I realized to take the check valve out of the compression testing set up.
If the '81's anything like the later cars, you'll want some special (short and thin) 24mm and 27mm wrenches so that you don't end up loosening (or removing) the sender housing instead of the sender. Once removed, the sender housing is a bit of a pain to get sealed properly afterwards... and you need to replace its crush ring, which is a special Roger order...
Last time I swapped a sender (on the GTS) I bought pair of those size wrenches from Advance Auto Parts, cut them in half with an angle grinder, and then ground the ends thin enough to fit side-by-side on the sender and its housing. The fab work on the wrenches was a bit of a pain, but it made swapping the sender a piece of cake.
If you just want to see things moving, you can probably jumper a multimeter to the sense terminal and ground and see changes in resistance as pressure builds.
Post #6 has some info I gathered from my '82 a while back.
https://rennlist.com/forums/928-foru...tter-ohms.html
How does one link directly to a specific post of a thread?
so you installed the started, did an oil change and then pulled the plugs right?
Is the car on an angle, front end in the air?
You should have got pressure with-in 30-45 sec
Has it been sitting a long time without oil?
If so it may take double that time but after that you may have to slip your belt off the pump and turn it with an air ratchet.
Brad
Brad
Here's the link .... https://rennlist.com/forums/7196388-post6.html
Re. SQLguy's tip about grinding spanners to fit, I am not
familiar with this job but it may be worth looking in a good
bike store for suitable spanners. There are several common
spanners that are very thin (say 3-4mm) and are in the larger
size range. I have some in my bike tool box for adjusting
head sets and bottom brackets. I can't remember the exact
sizes but they could be a better starting point than auto spanners
Before first start after putting my engine back together, we cranked it with the relays pulled to get oil pressure. After a bit of cranking, we got 5 bar showing (enought to reveal my cam tower oil leak).
Make sure the leads on the oil pressure sender are not reversed. Mine were at first, and it didn't show a reading on the gauge correctly. One lead/pin feeds the op warning light and the other for the op gauge reading.
Click on the post number in the top right corner of that individual post and it'll bring it up separately ... then copy that URL
If the
I managed with a 4" Crescent wrench and a cheap Sears (not Crastsman) open end.
If you take off just the sender you don't the the sealing ring. The sender has taper threads. See 59, 60 & 61.
Wires are correct, I'm going to try jumping while the ignition is on run. If that does not show, I'll remove the belt and try a drill on the pump it's self.
