WTB Black Sea Research Superclamp
#31
Inventor
With either clamp, folks should check the flexplate {at least} once a year.
#32
After one installs a clamp for the first time, important to replace and torque only the 4 most anterior bolts (2 per side). This way the lower bell housing cover can be removed easily giving access to your clamps. I check my tension/lack of movement every other oil change while the oil is draining. Piece of cake with 4 bolts. Thanks Ken.
#33
Rest in Peace
We will always recommend checking the flex plate/drive shaft pullout at every oil change with our Super Clamp.
Things can change, fail or break and with this being such an important engine health issue, checking it often would be prudent no matter what you are using.
#35
Yeah, well your contribution was far from clear so we had to pry the facts out of you.
Try to do better next time.
Good data trending, Bill.
I've had my PorClamp on for over a year after having end play pressure released. Need to do a re-check soon, but based on your information I'm not worried.
#38
