Crank sensor tooth 1.
Mr. Ducman; I know you were wondering about NA maping.
If I get a min tonight ILL send what I can to you.
on my system I use tooth #11 as per Tec - 4 GT instructions from Carl (base timing)
My map starts at 13deg at 650 rpm and is 36 deg at 7000.
of course is tunes up and down its self with verying map, temp, and tps signal
knock sensor detunes 2 deg per knock and climbs only 1 deg after
I am still tuning
Brad
I am still tuning
Brad
http://www.msextra.com/doc/ms3/trigger-wheel.html
under the "missing tooth crank, and single tooth cam" section is what I'm shooting for. right now i have the cam sensor at 80 BTDC.
trying to lock down the mechanical set up as close to what i need as i can.
