928 Forum 1978-1995
Sponsored by: 928 Specialists
Did I get a good deal on this 1982 928?
Old 06-05-2012, 02:44 PM
Avar928
Avar928's Avatar
Make sure your mechanic knows 928s inside and out because even Porsche dealership mechanics can screw things up and still get away with charging you $100+ an hour for it.
What Adamant said, don't sell your other car. The 928 is a beast but it doesn't fix overnight. Really read the FAQs, it has a plethora of information and will answer a lot of your questions or point you to where the guides are.
Avar928 is offline
Old 06-05-2012, 02:59 PM
brutus
brutus's Avatar
Originally Posted by MTM1989
........ My mechanic used to work for an exotic car dealer but he is so busy it is hard to get a hold of him.
If you will be paying a mechanic to fix your 30 year old 928 it will probably get rather expensive rather quickly unless you happened to have found an exceptionally good 928.
Planning on having it as your ONLY car one which you get into everyday and drive where you need to go with heat and A/C , and a good chance it will start when you wish to go home. You could EASILY spend $10,000 to have it refreshed enough to be reliable. It is not unusual to spend $2,000-3,000 a year on repairs and if the prior owners "Hoosiers" neglected it for two or three years you can guess where that leaves you.
Good luck with the car they make a great hobby if you enjoy working on old cars and do not NEED it to get to work every morning. Often as you are fixing one thing something else breaks and you have to mail order parts because NO ONE in St Louis especially the Porsche dealer has much of anything in stock. No big problem unless it is your only car !
brutus is offline
Old 06-05-2012, 03:02 PM
Adamant1971
Adamant1971's Avatar
Originally Posted by Adamant1971
Don't forget to read the FAQ's
Did I do something wrong, if so can you just tell me what? The FAQ's page is an extensive list.
You didn't do anything wrong, just encouraging you to read all of the FAQ's. It will help you more than you can imagine.
Adamant1971 is offline
Old 06-05-2012, 03:10 PM
Don Ashe
Don Ashe's Avatar
To answer your original question, yes, I think you got a great deal.
In my book, $4K for a classic porsche that runs, with a service history and decent paint is a great deal.
From the things you've already done, it seems like you've been doing the research, and the work, yourself, and getting good results, so just keep at it.
Congrats!
-don
I know it is kind of backwards to ask after the fact, but I jumped at this deal because I thought it was reasonable from others I have seen.
It is a 1982 928 auto (sadly not 5-speed) with 100,xxx miles. It was listed as a euro but I checked the engine stamp and it said otherwise. It has a full service history and has recently had new tires and a timing belt change. The paint job is a little rough in spots but looks good from a far. The interior is in good shape, the drivers side seat is a little worn but it is 30 years old and was previously been owned by hoosiers (St. Louis definition meaning rednecks not people from Indiana).
The only noticeable thing I can see that has been changed is the stereo. Instead of the speakers being built in the door they protrude out where the old speakers were.
The car runs great. I drained the gas, put in premium with an additive because it had sat for 2 years. I unhooked the factory alarm because the "safe mode" was keeping it from starting at times. There was some misfiring during the test drive but it was because the plastic electrical fuel pump connecters are broken and loose. If I get positive feedback I will be changing all the fluids and giving it a good tune up.
Finally I paid $4,000 and it came with a car cover, Australian sheep skin seat covers, original sales add framed, and a couple of Porsche signs. I am 22years old and this will be only my second car so I hope I did not just learn a $4,000 lesson.
The two interior picks are from the flyer so sorry for the bad resolution, will post better ones when I get a good lighting opportunity.
P.S. How do I make the pictures smaller?
Don Ashe is offline
brutus
brutus's Avatar
Lifted from another of todays posts .."My weekend project for this passed Saturday was to drop my fuel tank and locate a leak above the tank. When my father and I slid up under the rear end of the car, we discovered that the was NOTHING holding the tank in the car but the hoses attached to it! All 4 of the straps were there but they just ran down the sides of the tank and stopped as the guard pan had apparently been cut away by some previous owner which has turned my one afternoon project into now a 4 day project including cleaning the tank, repairing the leaking fuel line, drilling out a busted lug lock on the passengers side rear wheel followed by lug breaking insanity since the PO didn't request anti-seize on the lugs at the tire shop, OH... I almost forgot having to fabricate a new set of straps from the remaining pieces of the original by mating the mounting plate for the pump and filter to some very very tough galvanized strapping ! Does anybody else have this stuff happen to them? One small project turns into about ten? Is it just me ? Its a good thing I'm in love with this car because even after all of this I still can't drive her because the engine cuts out at about 1800 rpm (no clue why as yet since I've spent the last 4 days working on the wrong end of the car!)
Just an indication of the fun we often have when working on these cars
brutus is offline
Old 06-05-2012, 06:06 PM
NoVector
NoVector's Avatar
Just based on the pics, I would say "fair deal", but the service history, recent belt/h2O pump and tires would put it at good deal. Although hard to say without a PPI.
My $.02, start with safety stuff first (fuel hoses in the engine bay, brakes, CV joints, exhaust) then dump the fluids and then tuneup. And as crazy as it sounds, the more you drive these cars, the less problems you'll have.
NoVector is offline
Old 06-05-2012, 07:10 PM
danglerb
danglerb's Avatar
Nah, the faq is where many frequently asked questions have full and complete answers that have been vetted over time as correct. Questions you may not have even thought of asking yet, so despite length you should read it.
Training a mechanic on how to work on a 928 can be expensive, real expensive. You need a mechanic that already owns a couple sets of the work shop manuals, the special tools, and has learned years ago on somebody else's dime.
danglerb is offline
Old 06-05-2012, 07:58 PM
Dan87951
Dan87951's Avatar
OK deal. You are definitely 10k away from a 5k car (most are). Good news is you will definitely learn a lot about these cars so enjoy the experience.
Dan87951 is offline
Old 06-05-2012, 09:03 PM
MTM1989
MTM1989's Avatar
My mechanic used to work at a Rolls Royce/ Mercedes dealer where they also worked on Porsche and Lamborghini. I know he is competent and only charges $50 an hour, where as the German shop down the street was going to charge $1,500+ to change all the fluids.
MTM1989 is offline
Old 06-05-2012, 09:12 PM
MTM1989
MTM1989's Avatar
I was saying that the interior looks good despite the previous owners. Hoosiers was a bit strong, the only neglect he did in my opinion was having it for six years and not even putting 500 miles on it. The term hoosiers was more towards who they are so I was surprised it was in good shape.
Thanks for your reply.
MTM1989 is offline
Old 06-05-2012, 09:21 PM
MTM1989
MTM1989's Avatar
I plan on driving it regularly when I get it fixed up. Everyone keeps saying that they are not everyday drivers, but I've had my Mazda for 6 years and have barely put 30,000 miles on it. I BOUGHT THE CAR TO DRIVE IT! Unlike my neighbor who has a 12 car garage full of NICE muscle cars that haven't moved in the 13 years he has lived there. What a waste.
Sorry for that little anger tangent.
MTM1989 is offline
Old 06-05-2012, 09:25 PM
Kalspeed
Kalspeed's Avatar
I agree 100%
Drive her like she needs to be driven..you will see in time she will have her own personality..
Get the fluids et al changed..just as a precaution. Alarm issue now is not sooo important, I finally traced it to the rear hatch not seating properly and causing an intermittent light to come on and arm/disarm at will.
Kalspeed is offline
911 Crazy
SPAM addict
911 Crazy's Avatar
Location: Acadia National Park, Northeast Harbor, Maine
Put another $4k aside for future repairs. Sharks ain't cheap!
911 Crazy is offline
Old 06-05-2012, 09:32 PM
MTM1989
MTM1989's Avatar
Working on getting a second job. Bad time to get the car when having to pay for college, but it will be so satisfying when parking next to the ricers at my school.
MTM1989 is offline
Old 06-05-2012, 11:52 PM
soontobered84
soontobered84's Avatar
You said the car runs great. You seem to happy with the overall appearance of the car. If you are happy with the car, and you can drive it, then I say you got a heckuva deal!
soontobered84 is offline
Quick Reply: Did I get a good deal on this 1982 928?
