Funny stainless steel fastener companies reply to my question
#32
In the absence of oxygen and in the presence of the right electrolyte even stainless and stainless (yes I did say stainless and stainless) of differing alloys can cause corrosion of one of them at a rate that makes mild steel appear as long lasting as gold.
#33
The other thing to consider is the relative surface areas of the two metals.
If you have two equal surface areas of two metals one of which is only slightly cathodic relative to the other nothing much will happen.
However if you have a large surface area cathode in contact with a small surface area of something slightly less cathodic corrosion can be quite rapid.
#34
Years ago I worked on X-ray film processors. I saw more than one stainless steel tank (don’t remember if it was developer or fixer tank) where a paper clip ate right through the bottom.
#35
I am the tank.
