terminal numbers on S4 4 way seat switch?
I am trying to diagnose a problem with the passenger seat of my S4. The tilt of the seat back goes forward but not back. I'm trying to determine if it is the switch or the motor itself.
The terminals on the back of the switch where it is soldered are now impossible to read. Does anyone have a new one or one that is readable to see which terminal is which? The diagram is readable but I can't see the tiny numbers on the terminals themselves at all. Thanks in advance! |
The year of your car is ...
The car is an '88 S4. It has memory seats on the driver side. I don't know if that affects the passenger side. It has just the 2 sets of 4 way switches (not the heated seats)
At each 4 way switch the terminals are connected as follows:
1 - Brown 2 - Red 3 - Black/Violet 4 - Black 5 - Black/Green 6 - Grey |
well...IIRC, the motor cant be bad, as the two wires to it are reversed by the switch to make it work one way or the other.
IE: It doesnt have four wires to it, just two..and they are either + or -, depending. I could be wrong, but ive been diggin thru 12way+heat seat issues the last while..and Im down to a bad controller on one side I think now. |
Thanks for the help all! From what I understand here these are the terminal numbers:
http://www.lieberland.com/gallery/va...g?m=1336356796 This is the diagram: http://www.lieberland.com/gallery/va...g?m=1336356792 (that is not my ham-fisted soldering job...) So is X2 when I press backward to recline the seat back? Then would be shorting 6 and 2, grey and red, that would make the seat recline? When I tried that I just got a spark and dimming lights without seat movement which I deemed a bad sign... |
Bumping this thread. I am really lost here. Anyone know what terminals to short to get the seat back to recline here? X2 I believe is the switch.
I tried 2-6 again, that is not it... |
Originally Posted by kevinlieb
(Post 9509892)
I tried 2-6 again, that is not it... Seat Height Control is 3,5 / black-violet, black-green |
Sorry, perhaps I am being vague here. So if, say I wanted to make the seat recline, which two wires do I short? If shorting the 2 wires makes it recline but the switch does not then it is a bad switch...
(Post 9510664)
Thanks MainePorsche. Can anyone confirm this though? The current draw was pretty big when I did this: enough to heat the alligator clip to the point of burning my hand and dim the interior lights quite a bit. Didn't blow a fuse but it was definitely drawing a lot of current.
My theory is the switch does two things: connects pins 2 and 6 and disconnects some other pins.
I tried to take the switch apart in the car yesterday to clean the contacts. Bad idea! There should be one of those "no user servicable parts inside" labels on that thing. There are little springs and ball bearings that there are no way to get back in once they are apart, at least while it is soldered to the car. And the contacts are deep in there and hard to get at to clean. So I ended up cutting the wires off and pulling the switch off. Connecting the grey wire to the red wire (2 to 6 outside the car) did not make the seat recline and drew no current. So there is some other magic combination. Anyone have a full wiring diagram to the seat mechanism area? |
I don't think that simply shorting two poles on the outside of the switch is the best of ideas as there are multiple internal single pole double throw switches: moving the lever makes some connections while opening others. Adding an external jumper only closes a single connection but does not open any other, which does not give the desired results....
FWIW, I revived a couple of seat switches by drenching them with Deoxit. There were some small holes in the switch body IIRC. Not an elegant solution, but they are still working. HTH, Bob |
I am pretty sure that Memory seat (positrol) switches are different part numbers.
OK I now see no memory on the passenger side. |
Thanks Roger. I'll be ordering the switch from you today.
I would still love to know how to push the backrest back by shorting wires manually if anyone knows... |
