928 Forum 1978-1995
Sponsored by: 928 Specialists
What is this part for?
Old 04-22-2012, 03:41 PM
TheClairvoyant
TheClairvoyant's Avatar
Default What is this part for?
Can somebody tell me what this part is? It's on the passenger side of the engine compartment. I noticed it yesterday when checking out something else. It appears to have a vacuum line that is supposed to connect with it. The vacuum line is currently plugged with a screw/bolt (not my doing).
Old 04-22-2012, 03:50 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,539 Likes on 1,228 Posts
Diverter valve for the air pump.
Old 04-22-2012, 03:54 PM
NoVector
NoVector's Avatar
Air changeover valve. It allows air (being pumped by the air pump) to enter the exhaust ports in the heads which is used by the catalytic converters to heat up quicker--which reduces emissions. Or maybe it just dilutes the exhaust emissions so it'll pass a sniffer test.
If you get a chance, check out Tony's site for the "what's that?" under the hood stuff
http://members.rennlist.com/v1uhoh/underthe.htm
Old 04-22-2012, 03:58 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Nope. Not into the port but straight into the converter. The valve is a bypass valve.
Old 04-22-2012, 04:09 PM
Rob Edwards
Archive Gatekeeper
Actually, both of you are right. ROW, without cats, the diverter valve injects into the exhaust ports:
Old 04-22-2012, 05:08 PM
Ethre
Ethre's Avatar
You should be able to cap off that vacuum line at the throttle body if you want to clean it up a little and aren't using the air pump.
Old 04-22-2012, 06:34 PM
TheClairvoyant
Thanks for all the responses everybody.
I actually did cap it off and forgot about it !
A few years back a couple Rennlisters helped me install and x-pipe and high flow cats. The since the air pump wasn't being used, one of the guys capped off the line for me. I didn't remember until I found out that part was for the airpump today.
Thanks again.
Old 04-22-2012, 08:23 PM
NoVector
NoVector's Avatar
... I actually did cap it off and forgot about it !
I was thinking with a name like "the clairvoyant", shouldn't you already know the answer(?)
Quick Reply: What is this part for?
