928 Forum 1978-1995
Sponsored by: 928 Specialists
LED's in HVAC Controller
Old 04-12-2012, 02:34 AM
NoVector
NoVector's Avatar
Originally Posted by Bjbpe
... There is a site on the internet that offers to sell replacement LED bulbs for the instrument panel. It sounds like just a plug in job yet the various notes on this post sound somewhat more complicated with installing resistors and that sort of thing.
In my effort to out-elementary Mr. MainePorsche here are my questions:
What is the nomenclature for the bulbs that are normally in the instrument panel?
If it works for your MY 928, really recommend you use Ed’s guide. He linked the LED part/order numbers to the vendor's website--so ordering them is "just a click away". I think I ordered every LED he recommended plus the others body lights in the GTS Instrument thread. My point is, I must have ordered 50+ LEDs from the vendors he recommends and of all the LEDs, I only received one that was off-colored and they all worked. Both companies usually shipped the same day of the order too. Good luck!
Old 01-28-2013, 07:32 PM
Tony
Tony's Avatar
I know i have read it but it was buried in one of the other numerous LED threads.
Is there a good description out there on how to modify the fan **** itself to be illuminated.
I know there are 2 ways..
1) fiber optic
2) adding a small LED in the fan **** itself.
I'm interested in number 2....
I have the LEDs and resistors etc..
thnx
Old 01-28-2013, 07:54 PM
finally!
finally!'s Avatar
1) fiber optic
Using typical bulbs is a HUGE PITA and so is fiber optics
thnx
I did it multiple ways then finally settled on what I think is simplest.. Get a SMD LED (Surface Mount). They are small and very thin.
Drill holes in *** for the wires, leaving slack of course. Will have to toy around with different resistors to get so not to brigth. My first attempt was bright enough to damned near illuminiate the entire interior!
Simply glue it to the *** under the white fan looking thingy, run electric to it and done..
Old 01-28-2013, 08:07 PM
Jadz928
Jadz928's Avatar
What finally! said, Tony. That's how I did it.
Old 01-29-2013, 03:08 PM
Tony
Tony's Avatar
Got it done. I took apart one of the spare LEDs used for the back lighting of the cluster...it contains 5 surface mount LEDs. When viewed with a magnifying glass, each LED was marked + and - on its own board. I countersunk an area in the ****, drilled a hole, and ran the wires. I hot glued the LED in place and also place some over it as in one of Eds pictures. I then placed a "dime sized" piece of reflective aluminum tape over that.
The light reflects "outward" and not directly out through the ****. It also soften ups the light a bit and with some resistors i got the light level where i like it.
Old 01-29-2013, 04:12 PM
Ed Scherer
Ed Scherer's Avatar
Sounds good! FWIW, you can get those SMD LEDs individually from SuperBrightLEDs (and other places), too. That "Little Dot" one might be handy, if it fits.
It'll be interesting to see if the SMD LED will survive very long after being covered with glue. I think they run a little warm, so the glue might cause overheating and reduced lifetime. Keep us informed.
I plan on converting my HVAC head to this approach next time I'm in there, too; the fiber-optic approach was a bit klugy.
Old 01-29-2013, 06:35 PM
finally!
finally!'s Avatar
NEED PICS!
Old 01-31-2013, 04:40 PM
Tony
Tony's Avatar
Originally Posted by finally!
NEED PICS!
only thing I may caution is putting too much hot glue on the LED...it will interfere with the fan **** icon when you install it and as Ed mentioned perhaps heat build up will effect longevity?
Its rough looking but it works!
Quick Reply: LED's in HVAC Controller
