In-line Fuses???
In-line Fuses???
I am digging through an electrical issue and have the CE panel out of my '85 auto.
Behind the panel I found 2 in-line fuse connectors, both are small guage wire, I am guessing 18 ga. One is red with a black tracer and one is red with a white tracer. They appear to be original but I can not locate them in the wiring diagrams. One was in a clip on the back side of the left panel mounting bracket, the other one is floating in space.
The fuse in the red/white tracer line is blown, well maybe just died of old age but if I read the fuse correctly it is a 0.4 amp rating.
Anyone know what these two feed?
Team Owner
go to www.928gt.com and under tips and links find your fuse chart,
then scroll down you will see a note about these wire that you speak of.
Print one off for the car
Team Owner
As Wally said.
*Note: There are two 400ma Fuses behind the Fuse/Relay Panel for the Central Door Locks
Fuses are counted Left to Right 1-45 across the top of the Fuse/Relay Panel
Thanks Mr. Merlin.
I thought I had a goo fuse and relay chart but it does not list the items that are not on the CE panel so the 928 Specialist version will be a great help.
Roger
Roger
