Go Back  Rennlist - Porsche Discussion Forums > Water Cooled Technical Discussion Areas > 928 Forum
Reload this Page >
CLIMatronic HVAC controls for early 928's (and maybe late too)
928 Forum
Sponsored by: 928 Specialists
Old 03-10-2012, 05:43 AM
svpmx83
User
Default CLIMatronic HVAC controls for early 928's (and maybe late too)
Shhh
Although others are working on a plug and play solution for later vehicles, I thought some may be interested in the possibilities of the little project I have going on here.
Using MSGPIO from the guys that brought you MegaSquirt and the front half of a volkswagen B5 Climatronic unit.
based on the VW system with some alterations that make sense to me.
AUTO - Automatic temperature, footwell vent and fan speed mode - Pressing the button "AUTO" overrides the following settings.
- Fan Speed becomes automatic
- Foot and Centre Vent are controlled automatically
- AC Compressor control is turned on (ECON MODE reset if active)
- Defrost vent remains open if manually set - and can be turned off by def button as a toggle
In ECON operation, only the compressor is switched off. Heating and Fan/Vent operation continues to be controlled electronically if previously on AUTO or manually if in manual mode.
DEFROST Mode I
- Fan Speed Set to 4
- Foot and Centre Vent remain at current setting
- Defrost vent opens
DEFROST Mode II - Press and hold for > 1sec
- Fan Speed Set to 7
- Foot and Centre Vent Close
- Rear Screen Heater turned on
*** MODE RESETS to DEFrost I after 20 minutes or ignition off
OFF Mode - Press and/or hold FAN Down
- Fan Speed Set to 0
- Vents remain as set
- AC Compressor turned off
- Rear Screen Heater turned off
- Heater Tap is closed
Available at all times
Manual selection of air recirculation mode
Temperature setting 18-29c with LO (max cool) and HI (max heat)
- LO and HI will set fan to 4 if in manual mode
Manual options (all will turn off AUTO)
- Manual fan speed selection OFF , 1-7
- Manual selection of air flow to instrument panel vents (if installed)
- Manual selection of air flow to footwell vents
selected settings remain stored in memory after switching the ignition off and will be recalled on subsequent re-start.
Only the functions "Air Recirculation" and "Defrost II" are erased on ignition off or after 20 minutes of use.
Heating A/C Logic:
If connected to Megasquirt and
- starting from cold - coolant temp is used to hold fan speed low until engine
warms
- Engine load and RPM used to disconnect AC Compressor clutch on acceleration
I think the build page is now complete, fingers crossed of course.
No warranty - use at your own risk - Dont Try This at Home - for offroad use only - may burn your house down and/or damage the planet etc ..........
The three modifications are -
1. Servo bypass wiring as per instructions.
2. Solenoids are now Low Side driven so either - insulate and run 12v common - or change to a more common two wire insulated unit
3. PWM fan operation provides a grounding signal capable of sinking 4A. As our fans are High Side driven - an external Pchannel Mosfet or PNP power transistor is required - I used a toyota unit and changed the NPN tranny to PNP and altered the pull down to pull up.
I've not written 2 & 3 up in the build page
Draft build information http://www.reanimotion.com/GPIO%20Hv...structions.htm
svpmx83 is offline
Old 03-10-2012, 10:16 AM
fbarnhill
fbarnhill's Avatar
Well, tell us more. You have our interest. What price line do you antipipate? Looks like a pretty good idea. There are always room for more tha one solution to any problem. Think of what this poor world would look like otherwise.
fbarnhill is offline
Old 03-10-2012, 10:51 AM
svpmx83
User
This isn't intended to be a commercial offering, more a specific project with enough detail to allow copies to be made if desired. For someone to duplicate this setup would be in the vicinity of US$300.
Over the last couple of years several HVAC head projects have appeared on the board - some designs - one commercial project but none have been exactly what I was after.
Alan posted a pretty good list that matched my thoughts
The orginal controls were really badly thought out - they basically replicate a typical cable operated flap system model of the 70's.
So what to change: some ideas - you can pick & choose - most can still be plug & play - just a few need additional connections.
- Variable speed fan AND HVAC on/off (+some auto features maybe)
A recirc button that can be used at any time in any flap mode (its not A dist flap mode)
Incorporate the AC on/off button (why is it dangling out there today on A seperate panel)
Make the DEF function A dedicated override button - (its not A distinct flap mode)
- For the flap control ****:
.. - Relocate on/off it has nothing to do with air dist flaps
.. - Relocate Recirc it has nothing to do with air dist flaps
.. - Relocate DEF it does much more than air dist flaps and should be immediate
.. - Turns out there are only 4 real physical air distribution flap options on most 928s:
.... - Vents Only
.... - Vents + Footwell
.... - Vents + Defroster
.... - Vents + Defroster + Footwell
.. - On some older cars ('82-'83 I think) the console vent was controllable at 2 levels Open/Half Open/Closed.
.. - Ideally install one of these consoles for even more control... head unit connector has room.
Incorporate the rear defroster switching & monitoring
Alan
The VW CLIMAtronic head unit is a good match for the required functions while still looking correct/factory, and the absolute bonus here is that the front half of the unit can be separeted from the VW ecu giving a working faceplate which can interface to almost anything.
The hardware (GPIO) is something we've been playing with for a while now and should be familiar to the MegaSquirt guys on the board
svpmx83 is offline
Old 03-10-2012, 12:13 PM
fbarnhill
fbarnhill's Avatar
I don't suppose you would consider a writeup when finished to assist some of us electrically challenged individuals?
Old 03-10-2012, 12:45 PM
FLYVMO
User
FLYVMO's Avatar
Steve,
This is an excellent project, and I will follow it with great interest. Is this setup using the vacuum pods or can it control electrical servo motors for flap control?
Cheers!
Carl
90GT project
FLYVMO is offline
Old 03-10-2012, 06:49 PM
svpmx83
User
Yes, a write-up is in the works, so replicating the system will be feasable.
As for vehicle interface, yes the vacuum pods remain in place, with direct servo control of the heat mix flap, and digital control of the blower motor and AC compressor.
svpmx83 is offline
Old 03-11-2012, 12:00 PM
fbarnhill
fbarnhill's Avatar
Steve, that is awsome. Thanks in advance for taking the time to share.
Old 03-11-2012, 01:21 PM
FLYVMO
User
FLYVMO's Avatar
Steve,
Do you know if the electric vacuum solenoids receive constant voltage to keep the vacuum pods open, or do the switch on and off? Thanks again for sharing your work, I think it will be very beneficial to all of us.
Cheers!
Carl
FLYVMO is offline
Old 03-11-2012, 07:31 PM
svpmx83
User
the existing solenoids are driven constantly when on/active
svpmx83 is offline
Old 03-14-2012, 06:44 AM
svpmx83
User
Update for today
Display and button interface and software is completed
Currently working on the control logic, and will be basing it on the VW system as closely as possible.
AUTO - Automatic temperature, footwell vent and fan speed mode - Pressing the button "AUTO" overrides any manually input settings.
Manual fan speed mode
Manual selection of air flow to windshield defroster
In ECON operation, only the compressor is switched off. Heating and Fan operation continues to be controlled electronically.
selected settings remain stored in memory after switching the ignition off and will be recalled on subsequent re-start. Only the function "Air recirculation" is erased after 20 minutes.
svpmx83 is offline
Old 03-14-2012, 09:25 AM
hessank
hessank's Avatar
Subscribed!. I hate how dated mine looks right now.
hessank is offline
Old 03-14-2012, 09:41 AM
BigAl1
BigAl1's Avatar
That looks interesting for a flush console design! Can you show a pic of the B5 faceunit held in place on a center console to get a sense of scale? Thanks for your work on this!
BigAl1 is offline
Old 03-14-2012, 10:42 AM
yardpro
yardpro's Avatar
so are the temps limited to high and low?
are there any settings in between?
yardpro is offline
Old 03-14-2012, 10:53 AM
svpmx83
User
fixed above - LO-18c-29c-HI
so a normal temp range for the climate control with both a max cool and max heat manual override option
quick phone pic for BigAL
svpmx83 is offline
Old 03-14-2012, 12:37 PM
BigAl1
BigAl1's Avatar
Thanks for the pic - I LIKE it! Please keep us updated with progress and how-to.
BigAl1 is offline
Quick Reply: CLIMatronic HVAC controls for early 928's (and maybe late too)
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
