Brake Calipers Paint and decal recomendations?
Repainting the calipers and would like some advice on the paint used?
And who has the decals?
Thanks.
Thanks.
I really ONLY like the true Epoxy paints (2 part) for calipers. Do a google search for expxy caliper paint.
Anything else I've used does not withstand brake cleaner, or strong detergent cleaning.
Gary-
Gary-
hooked on cars has the peel off stencils if you care to do a multi stage paint:
http://marketplaceadvisor.channeladv...39&i=251963407
good luck on ebay otherwise.
I had trouble getting the stencils to work on the Epoxy paint. I used stencils there, measured the size of the OE paint letters (before sanding the OE paint on the caliper), and found essentially the same size decals in white (for the red S4 and GTS brakes I rebuilt and repainted) on eBay.
Gary--
Gary--
I just did this on Saturday. There are 2 types that I've seen. Spray on, and brush on. I removed the calpipers, scrubbed them, and scuffed them with 220 grit sand paper, I used the duplicolor ceramic caliper spray paint. It is easy to work with, and drying time is nice. under an hour to dry and 3 hours till you can handle them. Full cure takes 7 days. I can post later how it holds up.
I used G2 caliper paint and was pretty happy with it. Still looking good almost 10 years later. You need to work fast, though, to avoid the paint thickening too much, which will cause brush strokes to be visible.
Unfortunately, I can't compare it to spray paint, as I haven't done sprayed calipers myself (although I've spray painted rotor hats with VHT high temp ("FlameProof") paint and clear and that held up well, too).
I just noticed that Eagle Day sells some of this stuff.
Archive Gatekeeper
I have done a lousy job painting 2 different sets of calipers, one with epoxy paint and one with VHT caliper paint so I wouldn't dare give any advice on painting. I will put in a plug for the 'PORSCHE' stencils sold here: http://www.europdr.com/caliperstencil.htm
Despite my lack of painting skills they turned out pretty well:
eeeo
eeeo
Made up my mind. Two part epoxy and stencils. G2 caliper paint offers an aerosol spray paint attachment. PO used a brush to apply the red now on the calipers. I can see the paint marks.
I have half a mind to return to stock (black). Car and wheels are both black now. Decisions...
I need to touch up my Big Reds, anyone know how close a color match I can get with one of these products?
The G2 'orange' looks somewhat like it on the monitor. Duplicolor's red does not look like it ...
Archive Gatekeeper
Here's my experience with them:
https://rennlist.com/forums/928-foru...not-to-do.html
