Partnr. for fan shroud wiring clips and engine harnass adel clamps
Anyone have the part numbers for fan shroud wiring clips and engine harnass adel clamps? Can't find them in PET (yet they do exist ).
If you take samples to a big VW dealer and show them to the oldest parts guy there. He may recognize them and have parts. Porsche often did not sell clips, clamps, connectors seperate but used common VW items in their assemblies.
Archive Gatekeeper
These clips?
And by Adel clamps, you mean the Norma or GEMi-brand clamps like these:
Unfortunately I have no idea RE: part #'s for the shroud harness clips.
For the S4+ engine harness, there are 6 clamps. I only know for sure the part # of 1 of them, the big one holding the harness in the TB cover 'window'.
The original clamps on the spark plug bracket are RGSU-18's but they have a symmetric oval cross section, not 'D'-shaped.
1x at front right valve cover on lift bracket
2x at front lift bracket
1x at Left TB cover to block Norma RSG1 22 999 511 080 02****
1s at PS rack/crossmember GEMi 2.2
1x at PS rack ( 16 x 28 mm ID, 'X 4' stamped on it
Yes !
Great info! Now that I know the manufacturer I can search for a dealer nearby. Thanks again!
Archive Gatekeeper
At the risk of really outing myself as a PET geek, at one point a few years ago I went through and ID'ed all of the 999 511 XXX XX parts in the 928 katalogs.
Here are all the Norma/GEMi clamps listed in 928 PET pages. There are certainly others present on 928's that are not in PET, so this is not complete. And the US/Germany/NLA supply situation is likely outdated.
Code:
PPorsche pipe clamps 999 511 065 02 26/15 clamp for 928 A/C line NLA 999 511 066 02 GTS Y-pipe coolant need 2 Germany 999 511 076 02 clamp, B20 x 18 for LH harness x 1 U.S. 999 511 080 02 clamp B22 x 15, FOE harness x1 999 511 081 02 83-84 under front seat clip need 2 Germany 999 511 085 02 GTS fuel return line- RR fender? Germany 999 511 116 02 10' hose clamp for upper A/C line on right fender 10 x 15 10 hose clamp for fuel supply line at right front intake manifold 10 hose clamp for top right tranny oil cooler line on G2857 trans 85-86 928 B15 x 15 clamp- PS system US 999 511 118 01 GTS A/C pressure line along R frame rail (?) 15 x 15 US 999 511 124 01 83-84 928 L-jet aux air valve line clamp Germany 999 511 134 02 83-84 928 PS return line clip 10/20 need 1 Germany 999 511 138 02 GTS front wiring harness (at R shock tower?) need 1 NLA 999 511 142 02 clamp 17 x 15 need 1, on S4 LH page Germany 999 511 156 00 GTS battery cable clamps 13/15 W5 need 13 NLA 999 511 156 00 S4 power steering rack clamp (big oval one?) NLA 999 511 171 02 clamp on air injection lines on non-cat cars Germany 999 511 177 02 S4 LH harness clamp B20 x 15 need 1 US N 020 601 1 GTS '10' clamps on L body for PS return line to cooling loop
I am also looking for the clips on the fan shroud. Any luck in finding the part #'s or any substitutions. I know I can use tie wraps, but it is so ........ Non oem.
Bilal, I have a few - how many do you need - I'll set them aside for pick up at SITM.
I'll bring the entire shroud - You can put your fans into it.
How are your fan connectors?
Chronic Tool Dropper
You can get them from Eagle Day. They carry sizes for two different panel thicknesses and four wire/bundle diameters. I bought a few of each kind and threw them in the parts bin.
Mike
Mike
I need a couple and now know where to find a full set. Bilal, I have cable ties holding the harness in even where the clips are, since the clips seem to like to travel on their own sometimes.
