GT Cam Damage - Endless Spending
#32
928 Collector
Z, correct. Those pix are 5 and 6 second exhaust lobe.
From what I can see without turning the engine more:
3, 5, 6, 7, 8 all have damage to the second exhaust lobe (and lifter), and some of those show damage to both exhaust lobes and lifter,
All damage is on the trailing edge of the lobes, except perhaps 6, which seems to be pretty much on the peak.
#33
928 Collector
How usable would these be? They are not the GT cams. They appear to have no damage, but there are feint discolorisations across the bearing surfaces, maybe wear? These cams are dry. The apexes appear to be in excellent health. I don't know cams well... thoughts from cam experts?
#36
H
I have a set of S4 cams you can have for free...........granted its not ideal, but free is free
Did you check the rod bearings when you installed the pan? With that much metal missing, some of it must have gone through the bearings....
#38
928 Collector
arghh!!!!!! I wish I could help some how. . I have a set of gts cams you could have but that wouldnt do too much. My gts engine is arriving from gregs shop friday and it has gts cams with base circle grind that with 5 psi gave me 426 rwhp on mustang dyno. I could get those off the heads if you wanted( they were dr nicks)
just thinking .
andy
just thinking .
andy
I think I should take you up on this very generous offer thank you
#39
#40
Not sure what I am missing r.e. rod bearings. Oil from the heads goes back down to the pan and from there to the pickup, oil pump, and oil filter before going out the the bearings. I would think the oil filter would remove any metal residue that did not just sink to the bottom of the pan.
Unless the concern is just that the oil used was not up to the task and thus the rod bearing are suspect. But it seems that this is more of a GT cam issue and less of an oil issue.
Not to say inspecting the rod bearings would be a bad idea if the motor is out on a stand. You would not have to replace them if they look good, so you would only be out the nuts for sure.
#42
#45
