Recommendations for injector cleaning
I got one quote for 250 for injuector and fuel rail cleaning.
Anyone have any recommendations? |
What about a thorough & strong regiment of Techron, followed by an oil change??? Maybe it's beyond that, and just ignor me.:)
1 Attachment(s)
witchhunter did my injectors for the 928, came back looking like new. 2 of 8 tested fair before cleaning, then all good after cleaning.
just got my 911 injectors back from them. one did not test well, so getting a rebuilt. whatever the issue was with the bad injector, I had not noticed as I had no missing or sputtering. what I think I learned from both experiences is if you want to know they are all working properly, send them out. here is a pic of the 911 injector along with the fuel lines rebuilt by Zims. each cleaned injector returned in a separate sealed bag. in addition to cleaning, replace the prittle caps and gaskets/O rings. did this on both cars during rubber fuel line replacement. I just blew out the rails my self on both occasions. good luck. |
Why not put in the Ford 19# injectors? Much better spray pattern and then you have new injectors.
+1 for Witchhunter. I don't know what sort of issue would require cleaning of the fuel rail. I can't imagine those get clogged or oxidized, but I've never looked inside one - so who knows.
I had Witchhunter do injectors on my Z yeas ago. Very good service and been around a long time. |
how much do you think the ford injectors would run?
do you have a link to the correct ones? is there a mounting modification that has to be done? |
They are basically the same thing made by Bosch. Do a search to make sure but I believe you are looking for the ones with blue caps. Unless you plan to supercharge with a lot of boost that is all the pressure you will ever need. They are used in Ford 5.0 and I believe in Mark II's. It has been about a year since I purchased them but think I picked mine up for about $150 on Ebay. I am pretty sure Roger sells them as well.
My recommendation is always: Don't do it.
You can get a set of Ford Racing injectors for about the same price. 4 hole, brand new and they drop right in. I'm not a fan of refurbing injectors. I think they're a wear item that are cheap enough to replace that it doesn't make sense to hang on to the old ones. Edit: Guess I took too long to post. :) Check BlueOvalRacing. It's where I got mine. I don't think Roger has these because he can't get them any cheaper than they sell them for. I thought the S3s were 24 lb injectors though. I don't remember. |
Witchhunter did mine awesome customer service
You should be able to find a suitable set for around $250 or less brand new. Just remember not all injectors are the same-
The Ford sets typically come with 14mm O rings whereas the 928 needs a 16mm o ring at the bottom end [?]- easy enough to source. They are also EV1 connectors. You also need ot be careful to ensure they have the correct grooving at the top. Our injectors have either 2 or 3 grooves- some are supplied with 1 groove in the wrong place for our use [one of our listers cut hi sown grooves but not sure I like that idea given that holds the injector to the fuel rail]. Fred |
Originally Posted by FredR
(Post 9198615)
Originally Posted by Mike Frye
(Post 9198754)
I think that's for the S4 injectors. The ones from Ford are drop in replacements for the S3.
I assume there will be something in the Ford line up that suits the S3 Regards Fred |
Rick Cruze at Cruzin Perfomance. He'll clean them, add new pintle covers and seals, bead blast and paint them, and flow test them... runs about $130 for a set of 8, IIRC.
http://www.cruzinperformance.com/ |
(Post 9199114)
Part Number is 9593-A302. This is how I would go, rather than have injectors cleaned. You can buy them online from ebay or many other places and they are better than stock. Matt |
