My Leaky Tranny. I'm Screwed, Part II - NOW UNSCREWED - YEAH!
Under the Lift
Put a bolt into the threaded hole and use a slide hammer under the head of the bolt.
The stock gaskets are made from a material that seals very well to clean surfaces. Adding an additional sealant to this surface will make the gasket less efficient, not more efficient. The fact that he doesn't know this probably tells you all you need to know.
Pull the pump, figure out what is wrong, fix the problem, pull the pan, change the filter, and hope that everything else he did is correct.
Basic Site Sponsor
Basic Site Sponsor
My experience is that you cannot effectively flush an oil cooler that is metal contaminated. At least not without some serious ultrasonic bath process. The oil cooler has some mesh inside it that at least temporarily damns up the metal. I'm not sure what the tranny cooler looks like inside. How am I going to flush the tranny cooler that is in the radiator? I think I need to assume the metal contamination was rather limited and hope for the best. I'm mean, I'll do some sort of flush, but I don't think there is any practical way to be sure short of replacing lots of things. I don't see gobs of metal like I have seen before with bearing failures, where replacing was the only option, but I have some concern about where the metal came from and where it went.
Obviously, anything that the pump sucks up is filtered.
If the problem is after the pump (which it appears to be) and before the cooler (you will need to determine) you will need to clean out the lines and the cooler. I'd think that back flushing the cooler and the lines would probably be enough, as this failure looks fairly limited, in scope.
I am interested why the convertor could get installed so far as to rub on the front pump....that line around the "middle" of the convertor is very strange. The convertor "floats" in the oil pump...the drive lugs on the oil pump do not limit the travel. The distance that the convertor is "pushed" into the transmission should be determined by the rear flex plate. The flex plate depth/dimension is controlled by the circlip at the very "front" of the flexplate (right against the front flexplate bearing) which limits the flexplate from traveling to the rear.
Is that circlip present and sitting in its groove?
If that circlip is present and in the groove, the only thing that would allow the convertor to travel towards the rear of the vehicle would be for the rear flexplate to "bow"...which is not common.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Basic Site Sponsor
Basic Site Sponsor
Thank you, Greg. Oh, slide hammer! Yes, I think I'll go out an pop that pump off now. They guy came highly recommended, had all the credentials as a Mercedes mechanic, but I think whatever good luck he had rebuilding Mercedes/928 transmissions previously failed him this time.
People die from mistakes made at hospitals, every single day.
The measure of a good mechanic is what he does to fix the problem.
I assume that he has offered to fix the problem and all you need to do is take it back to him?
Team Owner
as far as the front pump gasket goes its best to wipe it off then put the pump back on,
no extra sealant as one side of the this gasket is firmly adhered to the trans main body,
if the gasket is wiped off then it should not leak.
A simple back flush with brake cleaner and compressed air will work,
drain the fluid into a clear container to verify that the fluid rinse is clean.
I am betting since it hasnt run long there wont be much if any contamination.
The converter may have been turned while on the bench and if this was done then it may have been rubbing before the flexplate was fitted,
you can also drain the oil from the TC and look for metal particles.
Under the Lift
Mechanics are only human and anyone can have a bad day.
Under the Lift
OK, I got the pump off. No more metal pieces inside that I could see.
One concern is that every part inside has an 89MY part number (there were changes between 88 and 89), except for the one he changed - the B3 piston. He used 88MY. He doesn't have access to PET, so he went off Mercedes 722 parts sheets. Perhaps that is of no consequence, but I just don't know.
Here's some pics. I think the rear bushing on the primary pump (pic 3) is burned too.
Under the Lift
Well, there was no goop on the primary pump gasket after all. It sure was stuck, so I suspected goop. When I took off my original untouched pump, it came away rather easily and the gasket remained adhered to the primary pump. [Actually the gasket broke.]
Stan, I think you're on to something regarding the two score lines on the TC. Greg, the rear flexplate is fine and the circlip is inplace. I was not aware that the flexplate held the TC away from the pump, floating as you say. Makes perfect sense. I will be sure not to turn the TC in the pump until the cover is all buttoned down.
I now recall that my donor tranny does not have a torque converter. I guess that means that I need to take the tranny back to the rebuilder and let him deal with that. Used ones are available for $500 at 928Intl at "regular" prices. [EDIT: George Suennen has the donor tranny. Turns out it does have a TC and the primary pump I need. If so, I'm going to remove those parts, inspect them and reassemble if they are good.]
Team Owner
the clutches seem to not be lining up did you notice that? picture 5
at some point before the flex plate is added the TC will have to be spun to verify that its seated
Under the Lift
Hi Stan:
I thought you only spun the TC until it engages the pump drive. Regardless I gather those scores are not consequential unless they happen from a bad cover assembly.
Yes, I saw that the discs didn't line up. Aren't they free to move once the B3 piston is removed? I'll make sure they are aligned before trying to reinstall if I end up doing the reassembly.
Under the Lift
Under the Lift
Under the Lift
