TT Bearings??
TT Bearings??
Why does my 928 not wanna go to SF??
On the drive to work, in the last 10 minutes it developed a grrowwwwl and vibration like you were going over the rumble strip on the side of the road..but lighter...coming from the middle O de car.
At 1800-2100rpm.
Not at any other RPM.
A diagnostic run up the RPM range to see if was anywhere else in the band..appeared to have cleared it.
Im betting TT bearing are on my short list now...too.
At 1800-2100rpm.
Basic Sponsor
Probably rear carrier bearings
Captain Obvious
Super User
Super User
There is a good chance that it can also be one of the two torque converter bearings. Regardless, the TT, needs to come off to see it.
Archive Gatekeeper
There will be many pairs of trained ears when you get to Anaheim.
Archive Gatekeeper
I think Roger means rear hub carrier bearings, AKA rear wheel bearings? Or he's talking about something inside that big black Rogerbox thing on automatic cars...
Basic Sponsor
Rear Carrier bearings or Torque Converter bearings - same thing. In front of the rear flex plate in front of the Torque Converter.
5 times out of 10 when the owner says he has a bad torque tube it is the carrier bearings.
My GTS had the same noises after I bought the car at about 60k miles. Torque tube was fine but one of the carrier bearings was shot. Bearings are $30 each so change them out anyway when you pull the TT.
Cant be anything that is road speed specific.
Could make it hum & growl in neutral rolling down the highway by using throttle.
Its gone away (testing over lunch) since the WOT tuneup.
Rear Carrier bearings or Torque Converter bearings - same thing. Behind the flex plate in front of the Torque Converter.
These bearings are in front of the torque converter flex plate. The snout of the flex plate assembly is pushed through the torque converter bearings which are pressed into the torque converter housing. They support the rear flex plate assembly that is bolted to the torque converter.
Cheers,
