928 Forum
Sponsored by: 928 Specialists
Coolant Leak Drip - What Is This - FIXED w pics - need help?
Old 09-21-2011, 02:20 AM
karl ruiter
If you are asking about the part I think then on CIS cars it mounts with a rubber bushing/stud thing. It has a rubber block in the middle and M6 studs that protrude on both sides. One side threads into the engine block and the housing sits on the other side with 10mm nuts coming down on top. Often the rubber part gives up. I have not torn a L jet car down to this level in a long time, but I think it was the same.
karl ruiter is offline
Old 09-21-2011, 11:58 AM
SanDiego928
User
SanDiego928's Avatar
Originally Posted by JHowell37 View Post
It's probably coolant. And before you say that coolant is supposed to be green, I know that. It sometimes doesn't always have that green color, especially in small quantities.
Yep - you are correct as I have just witnessed this first hand.
I see the coolant is green where it is pooling fresh and where there is dirt and soot it becomes an ugly brown color when pooling and also clear in small quantities when it is dripping slightly. Cool......
Will be pressure testing the system after work today to find the leaking area(s).
SanDiego928 is offline
Old 09-21-2011, 12:14 PM
SanDiego928
User
Okay, sounds similar. Just could not see anything in PET or maybe just not seeing the studs and nuts in that view. Seemed very odd to be able to move it around a bit.
Looks almost like working on some kind of aerospace assy. instead of a car down in there - AFM going into a curved shaped air funnel - updraft flap control - set for fuel burn in 3,2,1..
Old 09-22-2011, 12:02 AM
SanDiego928
User
Found 3 leaks under pressure.
2 hose clamps were loose. FIXED
Coolant leaking from here red arrow. What is this? Cannot find in PET.
Blue arrow is suspect also, any idea what it is called?
I plan on calling one of the big 3 tomorrow for this part but??????
Thanks.
Last edited by SanDiego928; 09-22-2011 at 06:18 PM. Reason: added info and blue arrow
Old 09-22-2011, 04:33 PM
SanDiego928
User
Parts Dept says this sensor is no longer being manufactured. Remove and plug up. Anyone know what I can use to plug? Size?
Old 09-22-2011, 05:27 PM
JHowell37
JHowell37's Avatar
I'm not seeing any pics.
JHowell37 is offline
Old 09-22-2011, 05:56 PM
SanDiego928
User
My error.
Thanks for looking though.
I am in a bit of a jam with this one. I think I got bad info on this part (sensor) from 1 of the big 3 since I can find what looks like this sensor at regular auto part stores on-line but not sure if it is the correct one or not.
Mark
Old 09-22-2011, 05:58 PM
Bilal928S4
Super User
Bilal928S4's Avatar
Cannot see the picture. I am on IE.
Bilal
Bilal928S4 is offline
Old 09-22-2011, 06:15 PM
SanDiego928
User
Bilal
My error. thanks for letting me know
Old 09-22-2011, 06:20 PM
WallyP
Rennlist Site Sponsor
I see no images. I.E.
WallyP is offline
Old 09-22-2011, 06:27 PM
SanDiego928
User
Pretty strange. I can see them in the first post and in the second post and the http:// links open up each picture in an IE new window.
Sorry.....I would certainly really appreciate your and others advice and you probably have the part the other sponsor did not have or at least tell me size a plug would be appropriate.
Mark
PS: It seems to be a coolant sensor directly behind and below the short hose to the HCV into the block or the hose assy support.
Old 09-22-2011, 10:01 PM
SanDiego928
User
Fixed pics. Had album set to private by mistake. My error. Had to fix a thread to find a fix for the 928. Thanks for everyone pointing this out.
Mark
Old 09-23-2011, 11:52 AM
ROG100
ROG100's Avatar
Check out PET MY81 illustration 107.25 item #29 Part Number 058 131 851 A My price $23.95
ROG100 is offline
Old 09-23-2011, 12:03 PM
SanDiego928
User
Wow, you are the MAN!!!!!!!
Thank you so much. I missed it on that illustration. Thermo valve? Never would have guessed that description, but does make sense.
I will be calling you today.
Thanks again - you made my day!!!!
Mark
Old 09-23-2011, 05:55 PM
SanDiego928
User
Talked with Roger @ 928sRus today on my issue and he took the time to go through my problems and how to save some cash on my other items I needed.
+100 thumbs up
I am on track to driving the 928 next week and on to Sharktoberfestest.
Quick Reply: Coolant Leak Drip - What Is This - FIXED w pics - need help?
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
