928 Forum 1978-1995
Sponsored by: 928 Specialists
Vacuum component needs ID
Old 09-03-2011, 07:57 PM
Stylemobile
Stylemobile's Avatar
Default Vacuum component needs ID
Some R+R revealed a small part that I have not a clue as to it's function.
It appears to have two vacuum nipples meant for rubber connectors.
Located under and external to the air filter box on the passenger side about 5 inches back and away from the throttle body. Here are two pics to help with the identifying. The photos are taken from the driver's side fender looking across the engine bay.
What is it? What is it's function and do I need to connect it to vacuum? Of note: I accidentally broke off the lower nipple. If I need this part, is it easy to remove? I could not figure out it's removal.
Please tell me what you know...
Thank You,
Allen
Old 09-03-2011, 07:59 PM
Stylemobile
Ahhh...... now that I look at my own photos, I can see how it is removed. (Note to self: Yer eyes ain't what they used to be.) Still need other data though.
SeanR
SeanR's Avatar
Most I encounter are busted off. Just connect the two vac lines that came off of it together and forget about it. I used to replace them but the cost of the valve just isn't worth it.
Old 09-03-2011, 08:47 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,451 Likes on 1,459 Posts
It is a temperature controlled vacuum switch.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 09-03-2011, 09:41 PM
ROG100
Basic Sponsor
ROG100's Avatar
058 131 851 A and we sell for $21.67 each
Old 09-03-2011, 10:20 PM
SeanR
SeanR's Avatar
You used to charge me 121.67....wassup with that
Old 09-03-2011, 11:32 PM
Stylemobile
OK. It's a vacuum switch. What does it control?
I have some other things to get from you, Roger so if this is useful and/or important, I will get one.
Cannot find the vacuum lines that went to it. Hmmmnnnn.............
Old 09-03-2011, 11:34 PM
Stylemobile
Sean, Greg and Roger: Thanks so far for the info and advice.
Old 09-04-2011, 08:00 PM
ROG100
Basic Sponsor
ROG100's Avatar
Sean I always charge you 4 x what I charge everyone else because you are so rich.
Old 09-04-2011, 08:05 PM
Stylemobile
Roger charges Sean 4X as much because Sean is so rich and Sean pays it because Roger is so lean?
Quick Reply: Vacuum component needs ID
