Wire repair: here's how I do it.
#63
I've been known to crimp and solder some connections. It often has to do with the quality of the terminals. Terminals for large gauge stuff is almost always crimp-only (usually meaty enough material that crimps well), but the terminals for small gauge wires are often pretty cheap and I just worry about pull-out or otherwise dodgy connection. Just a little bit of solder and you don't have to worry about it.
#65
#67
If it is subject to a lot of vibration, then you need to secure it better and use a crimp, they seem to live longer where there is a lot of vibration.
#68
"Correct, but it has more to do with most wires on aircraft being Aluminum than anything else, also a solder connection does not have the vibration resistance that a crimped does."
I have never seen an aluminum wire on an airplane. Tinned copper is standard in most places, with special high-temp wire where necessary.
"Just out of curiosity, how many of you folks that talk about doing work on aircraft have a A&P license? "
No A&P, just 30+ years experience in aircraft manufacturing/engineering.
#69
I think the reason there are so many bad crimps out there is because it is much more likely for a bozo with $5 to go out and buy some crap crimper and incorrect connectors at XYZ auto parts and do a crap job. It is much less likely for this to happen with soldering.
This does not mean that crimping a wire done properly is better/worse than soldering a wire done properly. Maybe there is a difference, but I would think it would be very small in such a case.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
#70
Big shops like a repair station or a airline, very few have a A&P, small general aviation shops, then most do.
#71
#72
#73
What kind of airplane with copper wiring?
Not sure I have ever seen much copper in a General Aviation type of AC.
