928 Forum 1978-1995
Sponsored by: 928 Specialists
Only sparks once...
Old 08-19-2011, 05:52 PM
Landseer
Landseer's Avatar
85 is buried (look closely for it), 86 is accessible!
Old 08-19-2011, 05:56 PM
por85928
por85928's Avatar
Originally Posted by neilh
^^^, yup. looks familiar - not much different to my 86. - before and after below.
Missing the test connector to the left of the oil filler, maybe?
WOW how long did it take to get it where it is today? Looks great! Nope the test conector is there just hidden under all the dirt.
Old 08-19-2011, 06:10 PM
neilh
neilh's Avatar
About a month of effort over about 3 months - cleaning up body was easiest, but also timing belt, CPS connector bad, some minor issues, transmission problems ( vacuum leak) , top end refresh, etc.
That test connector is great, and i used one of Porken's Blink'rs - makes adjustment very easy.
Old 08-19-2011, 06:16 PM
JHowell37
JHowell37's Avatar
Wow, another disco blue '85 with a blue interior. Just like mine when I got it. The disco blue had to go, or else I was going to send it to the crusher (which I probably should have done anyway.)
Are those the rare disco blue bumperettes? If you check the build sticker under the carpet in the hatch you should see the option code for them. The option code for body colored bumperettes is MAACO.
Change all of the fuses and replace at least three of the relays with the 53 marked on them. It's a commonly available 4 post automotive relay that's available just about anywhere. The 3 you want to replace are the LH, EZF, and fuel pump.
Does the tach needle move at all when you crank the engine? If it doesn't move, coupled with the one spark and dead oddity, I'd look at the Crank/reference mark sensor. The only way to test this sensor is with an oscilloscope. Since an oscilloscope costs more then a new sensor, you just buy the sensor and replace it.
Old 08-19-2011, 06:36 PM
Lizard928
Lizard928's Avatar
replace all the main relays (Fuel pump, LH, EZK), with new ones!
Replace the CPS with a new one.
Report back.
Old 08-19-2011, 07:07 PM
Landseer
Landseer's Avatar
Clean the fuse box, replace the fuses, clean the grounds. Or you will be right back in.
Change the fuel lines.
We already know it runs, lets do the job correctly.
Old 08-19-2011, 07:11 PM
por85928
por85928's Avatar
Don't know about the bumperettes, my build sheet is gone. As for the color is is not the original blue if you look at the engine pictures you can see it was more of a ice blue. Either way it is destined for a color change both inside and out. I will add all fuse and some relay replacement to the list. The tach needle does not move either...
Old 08-19-2011, 07:22 PM
neilh
neilh's Avatar
perfect symptom of a CPS or at the least the CPS 'bosch' style in line plug under teh air filter box that has fallen apart.... I had that on my 86....
Old 08-19-2011, 07:26 PM
por85928
por85928's Avatar
Thanks everyone for all the great tips and ideas I really appreciate it!
Old 08-19-2011, 08:01 PM
PorKen
Inventor
PorKen's Avatar
RE. MAACO code. If the transmission has been rebuilt, you may also have a AAMCO code...
I or someone can pull the real factory option codes using PET7 if you post (the last four digits of) the VIN.
Old 08-19-2011, 08:16 PM
Landseer
Landseer's Avatar
Beep Beep MCO
I forgot, when it gets running solidly and reliably, then add the Porken chips!!!!
Major improvement to performance!
Just sort it out first.
Old 08-19-2011, 08:19 PM
por85928
por85928's Avatar
Last 4- 1058
Old 08-19-2011, 08:47 PM
PorKen
Inventor
PorKen's Avatar
158/490/494 - Blaupunkt Monterrey, 8-speaker sound
018 - elevated hub 30mm steering wheel
319 - hot climate (smaller) fan pulley
418 - rubstrips
533 - alarm
650 - sunroof
Old 08-19-2011, 10:48 PM
por85928
por85928's Avatar
Thanks. Looks like the original owner went all out! The Blaupunkt is gone...
Old 08-19-2011, 11:01 PM
JHowell37
JHowell37's Avatar
Where are you located?
Take your time disconnecting those bosch connectors. I was able to replace my CPS a few weeks ago and did it without breaking the connector.
Quick Reply: Only sparks once...
