928 Forum 1978-1995
Sponsored by: 928 Specialists
Extended Wheel Studs vs Offset
Old 09-26-2016, 10:39 PM
WALTSTAR
WALTSTAR's Avatar
Default Extended Wheel Studs vs Offset
My 84 came from the factory with extended rear wheel studs and spacers. I assume that the spacers were to fill out the fenders and aid in handling somewhat with the non-staggered wheels. I have staggered 8 inch rears and want to know if I should still use the spacers or not. Would the combination put the center of the wheel more in line with the rotor hub? What would this possibly do to the nandling?
Old 09-26-2016, 11:44 PM
granprixweiss928
granprixweiss928's Avatar
Use the spacers with the 8" wheel if you :
1. like the look
2. Your tires dont rub the fender
Old 09-27-2016, 09:43 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,234 Likes on 1,236 Posts
the stock rear wheels without spacers were made to accept tire chains for winter driving,
adding spacers takes away this option.
adding 8 in wide factory wheels with the factory spacers will make the rear track about 42 mm wider,
you will not notice any difference in handling in most driving conditions,
you will see the tires look to fill out the wheel well
Old 09-27-2016, 12:12 PM
James Bailey
James Bailey's Avatar
No real difference in handling. Having run 15 , 16 , 17 and 18s with tires from 205 to 315 with and without spacers You will not notice any difference. A couple pounds of air pressure or corner balance weights has way more impact than spacers....
Old 09-27-2016, 02:13 PM
mark kibort
mark kibort's Avatar
all looks... and yes, do it!!! no downside all good.. wish i had the old 84 with the long studs! piece of mind to use the longer studs vs what i have now.. bolt on spacers with their own studs.. the spacer breaks, the wheel falls off.... not fun to think about
enjoy... you can run up to a 255 on a 9" rim with no issues with those spacers
Quick Reply: Extended Wheel Studs vs Offset
