TT replaced, now shifting, overheating problems
My TT has been replaced, but since picking the car up I've had a few issue not with the TT but with the transmission.
I first noticed after picking the car up it was reluctated to kick down, other wise everything looked ok. I had a visually check of the engine bay and the cables looked tight (maybe too tight?).
Next day whilst on the freeway, I slowed down for a traffic jam and then once on the move it seems the car would not shift out of 2nd. Due to the heavy fast moving traffice and no hard shoulder I was forced to drive a few miles with the rev up in the 4-5k range. The car began to overheat but did not hit the upper red line, stopped just under. The outside temperature was 104f.
I got the car off the freeway and parked up, then after a second or two coolant was hitting the road at the rear of the engine on the passenger side, the cooling fans where running and I could hear a burping noise from the rear under the air filter cover of the engine. The coolant resovior was full.
I have done nothing with the car since, any ideas where to start?
Chronic Tool Dropper
The TV cable from the throttle relay/bellcrank to the transmission should have a very slight amount of slack when the pedal is up. I keep mine adjusted at about 4 turns looser, and enjoy the later downshifts earlier upshifts in my casual driving. A few turns on that cable one way of the other will dramatically change the personality of the car. Right now mine is more of a Mr. Hyde.
Also check if the vacuum hose is connected to the modulator on the trans.
The coolant is no problem, just check if it spilled from the overflow hose which attaches to the reservoir neck and not from a split line or loose connection somehwere else. And fill up to the middle of the reservoir when cold.
Thanks guys,
I'll get under the car as soon as i can and have a look at the modulator, would the govenor also cause this problem of not going into higher gears? anyidea how to access that?
Things to check?
Trans fluid level.
Endplay / flexplate tension --- what treatment is used on your front clamp? Loctite or Constantine or PKlamp? (Does shop understand the causes of TBF and how did they compensate?)
Check for coolant leak under air filter. The passenger side heater hose nipple coming out of head S4 is failure prone ( I think flying scotsman did a review of this ) and heater hose is, too.
Did they remove pan when removing trans? If so, maybe filter on wrong inside, or, though pan is very strong, deflection of pan into filter that might restrict flow.
Above tbf reference is because of correlation between tbf and trans/tt work that has been reported; just be safe/sure on this.
Trans fluid level.
Modulator is on drivers side. Vac hose is rubber at bellhousing, then transitions to copper along top of TT, then to rubber near end of TT, looping down to mod valve.
A little tough to reach with exhaust / shield. Can pull off hose at valve. Check hose for vac with car idling. Then attach mighty vac to mod valve nipple, pump it down, see if it holds vac.
Things to check?
Trans fluid level.
Endplay / flexplate tension --- what treatment is used on your front clamp? Loctite or Constantine or PKlamp? (Does shop understand the causes of TBF and how did they compensate?) It has a PKlamp on it, they are aware of the TBF.
Check for coolant leak under air filter. The passenger side heater hose nipple coming out of head S4 is failure prone ( I think flying scotsman did a review of this ) and heater hose is, too. Will do as that is where I could here some noise
Did they remove pan when removing trans? If so, maybe filter on wrong inside, or, though pan is very strong, deflection of pan into filter that might restrict flow. Unsure, but I think they did not remove the pan
Trans fluid level.
