Preferred upper rear shock moisture barrier?
The part in the red circle bolts through the underside of the body and requires a seal between it and the body. The stuff that was in there looked like a liquid rubber or silicon of some sort. What do you use?
About the only thing not to use is silicon sealant unless it is neutral cure - ie doesn't rely on the evaporation of acetic acid to cure. As the acetic acid will get trapped and cause corrosion.
You can use pretty much anything else that won't rot, from string doused in stockholm tar, thro bitumen non setting caulk, to urethanes, however adhesive urethanes like sikaflex and auto windscreen adhesives are probably a no go as they are too strong - you'ld never get the plate back out in the future.
I think the easiest thing to use is self adhesive closed cell foam insulation strip - the thin stuff about 1/4" wide and 1/8" thick used for sealing around doors (in your home) to prevent drafts just stick it on the plate and push it in. No worrying about getting sealant allover the wheel well as you fumble about trying to insert the coilover from below with one hand and reach into the hatch with other hand to try and line up the studs and get a nut on one of them.
Team Owner
body shop supply store sells 3M dont know about Aussie though ,
also good for resealing the blower box
Rennlist Sponsor
I always knew using (most) silicone sealants on body parts almost always creates or speeds up rusting and corrosion in the area used...but I never knew exactly why until your post. I always thought it was because silicone trapped moisture so effectively it retained any moisture against the metal parts causing them to rust/corrode prematurely.
Learn something new every day!
Thanks again,
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
Chronic Tool Dropper
Marty-
I've used DAP weatherstrip caulk that you can buy at Home Depot. Roll out a strip in your warms hands to whatever size you want. May be more conveneint than looking for an autobody supply place with the 3M StripCaulk product. Also-- NAPA stores usually carry th 3M or their own M-S brand of same.
Marty-
http://www.oreillyauto.com/site/c/de...0481&ppt=C0171
Thanks for the alternative.
