928 Forum
Sponsored by: 928 Specialists
Is this a normal ground point
Old 05-21-2011, 03:43 PM
jacal128
User
jacal128's Avatar
Default Is this a normal ground point
I found this wire behind the passenger side coil, the large end was through the bolt and the small end was just hanging. Is this a normal ground point or something someone has probably added ? Thanks, Jack Attachment 538116
jacal128 is offline
Old 05-21-2011, 03:51 PM
jacal128
User
jacal128's Avatar
Post
Just checked the PET and it shows one, but not where the other end goes to.
jacal128 is offline
Old 05-21-2011, 03:53 PM
DR
Rennlist Sponsor
DR's Avatar
Normal, should have those ground cables on each side of the 32V engine coming from each coil bracket. Right side (cy 1-4) attaches to lifting ring (welded not on plate) just behind the rear/back of Cam gear backing plate.. Left side (cy 5-8) attached to threaded boss on rear/back side of cam gear backing plate. On 16V engine they bolt directly to cam tower housing.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928GTcom
Sharks in the Mountains on Facebook - 928SITM
DR is offline
Old 05-21-2011, 04:32 PM
BIMMERMIKE
User
BIMMERMIKE's Avatar
There's plenty of discussion about good ground connections and the effect it has for a good running car, so I wonder how did your car run?
BIMMERMIKE is offline
Old 05-21-2011, 04:41 PM
jacal128
User
jacal128's Avatar
Ran fine, just doing a TB and WP and fixing what ever I stumble upon while doing it. I'll check the lift point and see about mounting it there. Thanks, Jack
jacal128 is offline
Old 05-21-2011, 05:06 PM
Ed Scherer
Ed Scherer's Avatar
Ed Scherer is offline
Old 05-21-2011, 05:31 PM
jacal128
User
jacal128's Avatar
Got it, Thanks. Jack
jacal128 is offline
Old 05-21-2011, 08:37 PM
Landseer
Landseer's Avatar
It was added for radio noise suppression in 85, 16 & 32V.
At some point a wiper motor ground was also added.
A number of us have pointed at the coil ground as inhibiting start.
Not sure its realistic, though.
Its not even shown on the wiring diagrams.
Landseer is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
