Fuse puzzle
Fuse puzzle
Removed all of my fuses on my 1984 US model and replaced with all new fuses according to the original manual that came with the car. When I pulled fuses, there were fuses in all positions. I replaced leaving #2 and #13 empty as the manual says 'Not used'. Started and several seconds later the car dropped RPMs and died. Noticed when I turned key to restart no fuel pump sound. Put a 16amp fuse in #13 and she fired right up. Pulled that fuse while it was running and the car died again. Hmmm..... what could be different here? There is no problem- just a brain teaser at this point. I guess this is a crude way of determining fuel pressure is holding while the car is not running as the car had not been started for about an hour before I pulled the fuses.
All the Best,
Allen in Allentown, PA
All the Best,
