928 Forum 1978-1995
Sponsored by: 928 Specialists
After buying this kit..my rear end CRREEAAKKKS!
Old 05-16-2011, 12:41 PM
  #31
Bill Ball
Under the Lift
Bill Ball's Avatar
Jeff:
I'm back from ORR (George drove, I had to leave beforehand - 60 MPH wind gusts prevented George from attempting a 200 MPH run, topping out at 185). Let me know when you are going to be free, and we can pursue this further.
Old 05-16-2011, 03:55 PM
  #32
TheoJ
TheoJ's Avatar
Hi all,
I bought the same set from a friend inToronto-Canada who never used it. I had exactly the same issues. It is a design flaw IMHO. The nut starts to turn loose and the suspension starts making cracking sounds. Tighten it again, next day same issue. It is because the spindle that holds the shock turns a little when the shock is pressed and raised again. This makes it turn loose. You can see it on the movie on the first post. I do not think the design is completely thought thru and tested for a while. Also the bolt that links the upper droplink to the sway bar is too big. I did not want to drill in the sway bar (as per instructions) making it hard to revert to standard. So I made an insert to make it fit properly. Next step is making a bracket to move the mounting point on the sway bar further to the rear to change the effect. I did not fit the lower bracket again, which solved the mystery cracking and nut unscrewing.
regards
Old 05-16-2011, 04:08 PM
  #33
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Earth to Carl....Carl...calling Carl...
Old 05-16-2011, 04:26 PM
  #34
Lizard928
Lizard928's Avatar
it was installed, read his store policy. Once installed no returns etc.
Old 05-16-2011, 04:28 PM
  #35
Speedtoys
Speedtoys's Avatar
Lizard:
Where is anyone asking for a return?
Thanks for the....info...tho.
Old 05-16-2011, 04:39 PM
  #36
Lizard928
Lizard928's Avatar
nope, I realise that you arent right now. But just stating that.
I had these on my track car, and after a short time my back end started walking on accel/decel. These backed off the nuts.
Old 05-16-2011, 06:08 PM
  #37
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by Speedtoys
Bill:
I sure wish to heck I could make SITP..I cant.
Iceman cant make it..so that was likely the only chance to get it there for others to observe this geometric issue.
Odd that Carl hasnt piped in yet on this.
Maybe someone should send a PM before he gets bent out of shape for not being told of this thread.
Old 05-16-2011, 07:54 PM
  #38
blown 87
Rest in Peace
blown 87's Avatar
Why?
From the last issue it was pretty clear about his "Policies".
Old 05-16-2011, 08:02 PM
  #39
Lizard928
Lizard928's Avatar
Who said we were anyones mother
Old 05-16-2011, 08:10 PM
  #40
SeanR
SeanR's Avatar
Shame about this one, that is the one thing that really caught my eye.
Old 05-16-2011, 08:17 PM
  #41
blown 87
Rest in Peace
blown 87's Avatar
You missunderstood, what they said was "They are a bunch of *******"
Old 05-16-2011, 08:21 PM
  #42
Bill Ball
Under the Lift
Bill Ball's Avatar
Egad!
Old 05-16-2011, 08:44 PM
  #43
Ducman82
Ducman82's Avatar
i had that same issue. but i take it i did not torque the nut enough,
Old 05-16-2011, 08:48 PM
  #44
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,549 Likes on 1,233 Posts
I am 100% confident that I torqued mine to 103 ft lbs during the install but am getting creaking when turning into the driveway. Will check the torque on the nuts this weekend as I remove them to see whether that makes a difference.
  #45
Bill Ball
Under the Lift
Bill Ball's Avatar
Well, the nuts are described as "replace", indicating "single use", in the WSM. I've never changed mine despite multiple shock changes, and they have never lost torque (103 ft lbs). I don't have this plate installed. It seems the action of the plate may be working them loose.
Quick Reply: After buying this kit..my rear end CRREEAAKKKS!
