Just bought a TBF car
#32
Location: Magnolia TX, just north of Houston, Red 1984 S
We only hire ex NASA rocket scientists and former brain surgeons to work at the DMV......what are the emissions levels allowed on an in-op? (What they will do is title it as in-op, no emmissions, and then you will have to retitle it when running, will cost you another $33 to do that) I went through that on my last 2 928's
#33
Official Bay Area Patriot
Fuse 24 Assassin
Fuse 24 Assassin
Jim, did your cars come from non testing counties? Do you live in Harris county? If yes/yes, would love to know the process you went through. 4 hours so far and no luck.
#35
Barry,
You may be right on the wheel price. Here's a page I found, looks like they are still for sale, but they don't show a chrome option. Maybe these were chromed by someone else. Like I said, the chrome is not pefect, but you have to look pretty close to see the issues. I have to say, I like them a lot more now knowing they were expensive! Just thinking the ride is going to be pretty harsh.
http://www.nrauto.com/wheel_body.asp...&makeid=&type=
So, the base price for a painted wheel set was $2,995.00, with chromed versions as extra money (unless the PO had them chromed elsewhere -may explain the defects). By choosing '4' -you were pricing out 4 sets (16 wheels).
19" wheels shouldn't be any harsher of a ride versus 18"... they will still be a lower sidewall than the stock tires & many 928 owners have 19's without complaint. Once the car is running, try them out -you may be surprised!
#36
And no, the last 2 had LA titles....the 3rd one did have a Harris County title and expired plates
#37
Thanks Jim. Maybe Montgomery County has more logical procedures for this situation. I am giving up for today, but am waiting for a call to be returned from TX-DOT who appearantly sets the rules.
Got to thinking about something late last night...notice in the dash picture the fuel gauge is on E, and we did see some evidence of a gas tank leak? What if it's just out of gas? Maybe still with TBF, but at least I'd be able to move it around if it would run. Going to go out and put some gas in it now.
#39
and the add gas and test makes good sense to me...I would still try a dipstick sample of oil on dark paper and look for aluminum flakes before absolutely concluding this to be TBF.....just me thinkin' out loud....
#40
Jon, thanks I'll check that out on the hatch motor.
Barry, missed that, you're right, 3k for the set.
I hope I finally found someone at TX-dot that can straighten things out, he's the same guy that told the Tax office by phone it couldn't be done without emissions, twice, but appearantly he's had a change of heart, or found some new info, or something. We'll see if it pans out.
I think the car was out of gas, cranked on it some, then took off the fuel rail port cap and ball, and there was no squirt of fuel, just a few drops. I put some gas in, but the battery seems low, and it does sound pretty horrible cranking, so I don't gas is going to make much difference. I'm charging the battery now. No leak from the tank.
Just called the shop that worked on it for years, and the mechanic that worked on it won't be back till Monday, but they said no problem discussing the car and the final diagnosis.
I put some oil from the dip stick on a white paper towel and cannot see any metal flakes. Tried again to move the flywheel forward and back with a 2' screwdriver and it doesn't budge.
I'll try cranking it again with a full battery, then install the engine support I made a couple of years ago for my motor mount job, and start taking off the rack, cross member, etc... to get the pan off and have a looksy.
#44
Don,
You may be a lucky fellow if not TBF. No minute flakes of aluminum on a dark paper suggests maybe not TBF.
One thought comes to mind, after you charge the battery....the starter itself from the invoice you have was "used replacement starter". The starter itself maybe a problem...if it is dragging the armature it will eat all sorts of power and produce little...bad brushes usually fail differently, but I am just sayin'.......you might want to buy a lottery ticket too......I do have a fresh starter if you want to give it a try....
#45
We put it up on the lift after getting it home and found that the clamp was unbolted from the flex plate and we could not detect any end play movement while prying fairly hard with a small pry bar. The car turns over, but does sound a bit slow and of course doesn't start. The engine has had some attentention, and is fairly clean.
Its possible metal particles have dropped out of suspension to the bottom of the oil pan - I'd try to get it running first, then try the card test again once the engine's warmed up. If still clean, do the sump gasket and engine mounts, and inspect the thrust bearing with the pan off, just to make sure. Sure its a bit of a pain on the labor side, but if its good you're still improving the car, and if its bad you've saved yourself more headache
You may yet be lucky.
