Shock install concical washer confusion
Unfortunately I had a link that took me to the presentation and not the entire rennlist post so I did not see the follow on comment.
I had not put anything togather yet as the write up pic did not match the WSM or what I found when I took it apart so having seen some of the other PO's work I could not trust the way i found it to be the definitive way to put it back togather.
Under the Lift
Here's the original thread about this. Tony is aware of the error in his otherwise excellent shock replacement guide.
https://rennlist.com/forums/928-foru...-resolved.html
Got it back togather last night very quickly. Reviewing photos I had taken before disassembly it had been put togather correctly when last reassembled.
Now on to the other side and then adjusting the rear ride height.
I am struggling to find the hub pin and lower sway bar link bolt torques. WSM table isn't using the same terminology I do
Thnaks for all the help!!!!
I went back and forth from the torque table descriptions to the rear shock and suspension assembly diagram in the WSM and could never connect part terminology from one table to the other.
Am I an idiot or do other folks run into the same issues? Don't worry about answering the first part of this question as I know the answer!!
LOL! Hey, are you driving that bad boy to 2nd Sat *** GTG tomorrow?!
I am going to bring the silver GTS because Mike will be joining us (his first time to a 928 GTG) with his '95 Polar Silver GTS! Will have one of the very first and very last GTS's both in PS at the GTG! Hoping to take some pics of them side by side!
One of the guys did a super-duper torque chart, maybe Rob Edwards? I have an Excel version, I'll print a hard copy and bring it to lunch tomorrow in exchange for a couple of Blake's french fries ;-)
